Hello everyone, I have a problem. About a week ago I heard a noise from under the hood. Checked it out and it was the hose coming straight from the PCV valve. On my way home my car started surging really bad and and I couldnt give it much trottle ( it wanted to die and surged really bad) I had to baby it home and barely made it in the drive way. I replaced that one hose that was bad. But went to start it and nothing, just cranks. Checked the IFS in the trunk and it is good. I can get it to start if I crack open the schrader valve on the fuel rail while cranking it over but when it does start it runs rough and wants to die. Cannot give it too much throttle too quickly. Seems like it its running lean, no check engine light. Will not start unless I Hold the schrader valve open to bleed. Cleaned the IAC valve and it did not work. ANY ADVICE?
Have not tried starting fluid. I haved checked all connections from MAF to TB. Even taped up the connections to eliminate leakes there.Made sure clamp at MAF was on correct and tight as well as at the TB. Made sure all Vaccum lines were intact and hooked up to appropriate component. There is no theft light on. I OHMN checked the FRPs and I did not get 0 any way i tried. I read it shoudl read 0 ohms. It will randomly start now but runs rough and dies in less then a minute. I have now replaced the FRPS. IT DIDNT WORK> I installed the FRPS and it actually fired up after cranking for a few seconds but it ran. It ran fairly smooth and smelled no rich exhaust. I tried to rev er up and she died. After that, crank and no start. Im tired and pissed. Will try tommorow. Thanks to all who replied.
