no start, NO fuel Pump or Spark
Raginstang
166
SANTA CRUZ CA
I just finished hiding my wires under the fenderwell on the driverside, and now the car wont start, it cranks, but the fuel pump doesn't come on and there is no spark? checked the grounds and seems like everything has power. I just moved it all, seems weird.. any ideas? oh, and when I try to ground the fuel pump test lead, nothing happens.. but it says the lead is a ground... with a test light... maybe no power to eec? thanks for any help
first off, thanks for the replies, second , yes I feel I have everything connected, just maybe not to the right places :) third, yes I have ll the fuse links connected to the battery side of the solenoid, and I think I have all of the grounds hooked up.. seems like the ecu doesn't have power now or something, I mean no fuel pump or ignition, but it cranks. thanks.
Did you see the ground that was hooked by the starer relay that had a plug about 6" up?? If I remember correctly it was gronded to the apron and one lead went to the battery ground side. If that ground isn't hooked up the FP won't kick on when the key is turnd on...
also, I can hear the ecu relay click when I turn the key to the run position, and I can also hear the coil make weird noses when I hook and unhook the grounds. still no power or something , fuel pump still wont turn on or no spark. gettin mad here, looks like all is hooked up, and all fuses are good.. bout ready to drive it off a cliff
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set emergency brake. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if present.
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the black 10 pin connector.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
YO, just so ya all know, I fixed the problem, I had a wire that needed to go to the solenoid going to ground, it was purple, and I am a little color blind, "seriously" and thought it was black. well, thanks for all the replies, and im sure I will be posting again :) he he, just before I got it off the cliff too
This is the EXACT Problem I am having after moving my solenoid to the inner fender... so far I have spent about 6 hrs trying to figure our WTF is wrong... and still have no clue. I ripped the EEC out and that is not getting power when the key is turned.... do you remeber how many wires when to ground by the starter solenoid? I have 3 wires going to ground but two of the wires... and black/green and black are coming out of the same wire look so I was wonering if maybe one of these goes to the solenoid... but then why is my eec not getting power???? and then I was wondering if the starter solenoid needs to be grounded good itself??? cause the bracket i made is out of aluminum......... the car cranks over fine...... IM about to push MY car over the cliff now!!!!!!!!!
WTF!!!!!! I must be color blind also... I too had the purple wire hooked to ground. After reading this post I went out and realized it was purple..... hook it to the solenoid and the car fired right up!!! but my check engine light is on as well.....
Does anyone know what this purple wire is for??????????????????????????
I'm coming up with lots of purple wires on the wiring diagrams. Does the wire have a second color stripe on it?
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
