no wind shield wipers....help
  • Thread starter Thread starter jmd2914
  • Start date Start date Aug 27, 2005
J
jmd2914
937
Napa, California
Aug 27, 2005
  • Aug 27, 2005
ok, i took my wiper arms off and painted them along with the cowl grill and the trim on my car and the painting turned out good, but now i have everything back together but i cant get my wiper arms back on. i know its a dumb question but could someone walk me through getting them back on?
HISSIN50
34
129
Aug 27, 2005
  • Aug 27, 2005
I think I had to bend the arms out (like if cleaning the windscreen) and pull the little tabs on the arms out (those same ones you had to pull out to release the arms upon removal). Then slide the arms onto the splines. I put a little grease on the splines before installing them - might help with future removal.
Good luck.
88gt
794
Drillers cabin
Aug 27, 2005
  • Aug 27, 2005
How did you take them off? Did you lift the blades up and slide the little dammit clip out to hold the blade section up? If so, did you release the dammit clip to finish painting them? You need to check that little clip on the end where the arms are held in place, make sure it is not interfering with the reinstall.
Jim
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
A
Resolved Windshield wiper troubleshooting - Wiper turns OFF when Headlights turned ON
  • afjLX
  • Feb 9, 2025
Fox 5.0 Mustang Tech Mar 30, 2025
General karthief
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
