no wind shield wipers....help
jmd2914
937
Napa, California
ok, i took my wiper arms off and painted them along with the cowl grill and the trim on my car and the painting turned out good, but now i have everything back together but i cant get my wiper arms back on. i know its a dumb question but could someone walk me through getting them back on?
I think I had to bend the arms out (like if cleaning the windscreen) and pull the little tabs on the arms out (those same ones you had to pull out to release the arms upon removal). Then slide the arms onto the splines. I put a little grease on the splines before installing them - might help with future removal.
Good luck.
How did you take them off? Did you lift the blades up and slide the little dammit clip out to hold the blade section up? If so, did you release the dammit clip to finish painting them? You need to check that little clip on the end where the arms are held in place, make sure it is not interfering with the reinstall.
Jim
