Noise from my fuel rails, wont start....
88gt373
140
hey folks. Im pretty new with mustangs in general and i just caught the FOX bug about last year and had about 3 mustangs. now i have an '88 GT hatch. heres what i did:
acid dipped a 93 block (stock bore, fresh hone)
rebuild stock E7's w/ frpp double springs stock everything else)
E303 cam
arp everything
felpro gaskets from top to bottom
bbk shorty headers, super 40 flows, stock H pipe, two empty cats!!!
everything else is stock, i just painted the engine bay and motor: its a real clean rebuild...ill post pics when i fix my camera.
but here is my problem.... i buttoned up everything the other night and when i went to start the car i heard alot of clicking coming from the fuel rail (fuel system is all stock)... i proceeded to check the fuel system. i can hear the pump going and the injectors go off like crazy. i unplugged the harness going to the injectors and they stop making noise but it sounds like the regulator. any ideas?
btw the car was sitting with an empty engine bay when i got it (63,000 miles!!!) it was under a car cover for about 3 years with the engine harness and fuels system wraped in a bag. could the reg be making this noise cuz its stuck??
:mad:
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 05-Aug-2010 to add check for distributor timing in paragraph 6C.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
wow. looks like i got some home work. i took off the upper intake to get to the injectors. i noticed a solid orange wire from the white connector that was cut and i cant find the other end. any ideas?
That is the O2 sensor ground - very important. Crimp a new lug on it and bolt it down to a clean shiny spot on the firewall or intake manifold.
kool. thanks. its good to get help on a timely manner.... so i ran through the tests on your post reply and all is ok. the starter is fine, i get spark....all the fuses and in-line fuses are ok. but everytime i put the key to the on position the injectors are making tons of noise again. so i unplugged the harness to the injectors again. i can here the fuel pump going like crazy..... i removed the relay under the seat just to isolate the problem. and its deff an electrical/fuel related issue. i removed the pressure regulator and turned the key and fuel continually pours out the rail. could the regulator be the issue?
See step 4F in the checklist. Most regulator failures are from a leaking diaphram that allows fuel to dump into the intake manifold by way of the vaccum line attached to the regulator.
fuel pump pressure test
Disconnect the larger of the two fuel lines up by the Schrader valve. It is the return line and does not have the Schrader valve on it. Find a piece of rubber fuel hose and clamp it on the return line coming from the regulator. Stick a bolt in the other end of the hose and make sure that all your connections are tight and leak proof as possible. When this powers up, you don't want fuel squirting everywhere. Hook up the fuel pressure test gauge. Turn the ignition switch on and watch for leaks. You may want to use a helper inside the car to cut the switch off quickly if you have a leak. To trick the fuel pump into running, find the ECC
attachment.php
Caution!!! You have blocked the return line for the fuel pump! Pressure will rise very quickly past safe levels with a good pump
If the pressure goes up past 55 PSI, the pump is good and the fuel pressure regulator is bad. If the fuel pressure does not hit 55PSI or more in a few seconds, the pump is bad or you have electrical problems.
alright. so i had to buy a fuel pressure gauge for the test you posted above and my pump is fine. it shot up to about 54 pretty quick and i also tested it coming out of the pump. a friend of mine had a new pump in a box so i installed that just to get rid of that 22 year old pump. :D
i still am getting sound though. a buddy of mine suggested that it was the CRANK SHAFT POSITION SENSOR. i checked around my crank and dont see any sensor close to there. BUT.... on the wire harness by my starter solinoid, there are two connectors that aren't going to anything. one is a double prong female end and a smaller one or two wire harness. could a crank sensor cause my fuel system to spazz up?? where exactly is my CKP sensor on my 88gt?
thanks
There is no crank sensor on our cars. What does the noise sound like? My injectors make a slight noise when i prime the pump, its almost like a hiss, does the car crank? stupid question but is the firing order correct and counter clockwise?
the car cranks fine but wont catch. it just turns over. and i triple checked the dist. and the wires and all it ok there. but right now i have the upper intake off and and harness to the injectors unplugged. when i put the key to the on position (when the harness is plugged in) the injectors all go off like the car is on. and the fuel pump is really loud. i took off the FPR (with the injector harness off) and fuel deff pours out. im at a loss right now. :shrug:
Please list the wire/stripe colors of the wires that are loose and not connected. They may have some bearing on your problem. Don't try to use pictures instead of a good description. Pictures of 23 year old wiring caked with dirt are not very helpful. That, plus the color reproduction is often less than suitable for proper identification. Clean the outside of the wire if necessary so you can tell what the color of the wire and stripe really is.
Your 5.0 Mustang does not have a crank sensor. It has a PIP sensor inside the distributor to trigger the TFI (spark) and computer (fuel injectors). See item 1B on the checklist.
Crank sensors are used with distributorless ignition systems in Ford vehicles.
I really suggest you re-read the Cranks OK but no start checklist again and again until you have a better picture of how the whole system works together.
You have fuel, do you have spark?
Have you used a Noid light to check for injector pulse?
Will the engine try to start if you squirt some starting fluid in the throttle body? See item 3.0 on the checklist.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Listen to Jrichker, re-check that list for no start. I had a similar issue on my 93. I had spark, power to the injectors, fuel pump, fuel pressure, I could get the car to run on starter fluid. I eventually found I wasn't getting ground signal from the ECM to the injectors. I found this by following the no start checklist, trust me, it works. Good luck with the issue, I would look towards that computer, especially if mechanical issues check out and the car sat for awhile.
ok. to the bat cave on this one... im at work and im going to use that diagram and check the grounds and signal wires. and yeah, the car was sitting for about 3 years under a tarp ina drive way and garage, so im sure i need an nice walk thru on the electrical. thanks guys. ill let you know how far i get.
