Noisy injectors?
  • Thread starter Thread starter 88LX
  • Start date Start date Apr 18, 2004
88LX
327
Chicago, IL
Apr 18, 2004
  • Apr 18, 2004
theres a clicking noise from the engine compartment and theres a fluttering noise that i can hear inside the car while driving. how noisy are your injectors? will getting a fuel system cleaning help, if thats what the noise is? very annoying, i hate mystery noises.
dastang2
2,020
tx
Apr 18, 2004
  • Apr 18, 2004
that is most likely lifters
HISSIN50
34
129
Apr 18, 2004
  • Apr 18, 2004
the injectors making noise (clicking) = they are working.
most make noise, but the noises from the rest of the car drown them out.
88LX
327
Chicago, IL
Apr 18, 2004
  • Apr 18, 2004
ok thanks guys. anyone else have an opinion? should i get the injectors cleaned or should i pull the valve covers?
dastang2
2,020
tx
Apr 18, 2004
  • Apr 18, 2004
is it running bad, i have never heard injectors make a noise before, especially over the mufflers and fan. to change the lifters you need to pull the intakes too.
88LX
327
Chicago, IL
Apr 19, 2004
  • Apr 19, 2004
maybe i should have said that the noise that i hear is at idle and when im either outside the car or inside with the window down. what do you suppose is bad with the lifters?
HISSIN50
34
129
Apr 19, 2004
  • Apr 19, 2004
if you think your injectors are messed up, you can run a balance test on them. read up on pulling codes and it will test them. if it finds something out of spec, it will refine the test to check them further.
if you dont hear an injector click, wonder if it is ok. it is just that, as said, one normally does not hear them over other engine noise. i have to use a stethoscope to hear them.
but it is real hard for any of us to diagnose the description of a noise like yours.
good luck.
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
