non-roller to roller help
  • Thread starter Thread starter feifong
  • Start date Start date Mar 11, 2006
feifong
319
mesa
Mar 11, 2006
  • Mar 11, 2006
Im gonna have my engine torn apart and want to convert my 83 vert non roller engine to roller what do i need to buy to do this?
M
mikemustang289
224
mesa, az
Mar 11, 2006
  • Mar 11, 2006
Comp cams sells a retrofit kit, cam, lifters. Some kits I've seen use a stock style spyderweb assembly which you have to tap the block in 2 places for to bolt it down.
I am not positive but I think they make kits with linkbar type lifters so the spyderweb is not needed. Just search on comps site www.compcams.com
DeadLifter
183
Portland, IN
Mar 11, 2006
  • Mar 11, 2006
I believe you'll need to change the gear on your distributor too.
txstang84
1,639
42
69
Tuscola, tx
Mar 11, 2006
  • Mar 11, 2006
you're absolutely right, going on that, if you want to stay with duraspark ignition, just run down to your local parts store, and grab a dizzy for an '85 GT vin code M (4BBL HO), that was the first, last, and only year the carb'd mustangs came with a roller cam. It will come freshly reman'd with new everything, including the steel gear for about $50 + your old core ($30)
if you wanna swap to a standard style roller cam, you have to buy the linkbar type lifters...which run about $400. If you want to use the stock type lifters, then yes, drill and tap the lifter valley to run the spider and dogbones, but you'll have to use a reduced base circle cam. those run about $300 from Comp. I'd thought about doing that swap in the past, and after running all the numbers it just was more advantageous for me to wait and get a new badass block (which I'm still doing), so I can use standard dimension parts.
The reason behind it is the lifter bores...the older style non-roller blocks have shorter bores than the roller style blocks.
feifong
319
mesa
Apr 22, 2006
  • Apr 22, 2006
So i cant run standard lifters of say an 85 .. And a standard roller caM? Is the only difference in dizzy is that one is a cast iron gear and rollers are steel?
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
