Matt is correct about the percentages - having them all within 10% is much more important than absolute numbers.
If wanting to roughly compare numbers to other members' numbers, one should:
Do the test on a hot motor.
Have the ignition and/or fuel system disabled.
Have the throttle at WOT.
Have a charger on the battery in case it drains as you crank.
On those two weaker pots, I would try doing a wet compression test on them. I would not at all be surprised if the pressure went a good ways up. If it does, that suggests your rings are letting a little compression bleed past.
A leakdown test is the next step up for further compression-based testing.
Good luck.
