notch the block
stang9150
142
i have been doing some work on my 331 setup,do i need to notch the block for clearance or is that only for 347 strokers.If i do need to do it how do i go about it,anyone have a link on the subject to show how its done.thanks
My 331 only required clearancing at the bottom of the cylinder and not near the oil pump mounting pad. This was on a Mexican 302 block so on a late model block it may be different.
As was mentioned above, you'll have to do a mock up on each cylinder to determine placement of the notch.
