now whats broke!!
  • Thread starter Thread starter mustangsquared
  • Start date Start date May 4, 2004
mustangsquared
828
new bern nc
May 4, 2004
  • May 4, 2004
Ok, if its not one thing its another. I have a strange thumping noise that is only heard under load and increases with RPM's. Now the fun part...it only happens sometimes...thats what is throwing me for a loop. Any ideas???
SCORPION
386
Seaford, DE
May 4, 2004
  • May 4, 2004
what do you mean "under load"?
check your tires for any bald spots or if its missing balancers.
mustangsquared
828
new bern nc
May 4, 2004
  • May 4, 2004
When I push the gas pedal down (clutch engaged or not). I just got new tires on Friday (balanced/new allignment). It only occurs when I hit the gas/hold the gas pedal down to maintain speed. I had a surge problem...still have it on occasion. I just added a "Screamin Demon coil and ignition module". RPMS dropped by 150 after install (reset timing). The noise is not a crackle but a steady clunk that increases frequency in relation to RPM.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 4, 2004
  • May 4, 2004
it could just be a miss or a back fire. i had that sort of problem before. kind of a hollow thumping/popping noise. check your plugs and wires and than recheck your timing
88stangmangt
2,332
Stafford,VA
May 4, 2004
  • May 4, 2004
could be a loose or broken rocker? with that vague of a description no one can give you a 100% answer.
Legendary
1,925
City of Angels
May 4, 2004
  • May 4, 2004
Does it only do it when the car is rolling or sitting still or both? Coming from front or back? Any strange vibrations? If under the hood try reving the car up from the TB and see if you can pin point where it's coming from.
mustangsquared
828
new bern nc
May 5, 2004
  • May 5, 2004
I revved it up (from under the hood)... I think it is either coming from the passanger side back corner of the engine OR the manual transmission. It comes and goes. I have rechecked my TPS (.99), rset timing to 11* BTDC (Spout disconnected), rechecked my wires, plugs are only 2 months old. Cleaned the TB, IAC, Intake. Had oil change a week ago, 4 new tires and front brakes (pads and rotors, repack bearing) this past weekend. It is not a rapid fire crackling but rather a slower more steady "thump/pop" that will increase with RPM. I looked under the car and checked the sheild on the lower bell housing, the trans mounts, motor mounts, exhaust... all good to go.
Could it be a bad O2 sensor? I still have a surge problem on occassion?
Legendary
1,925
City of Angels
May 5, 2004
  • May 5, 2004
Are you sure it's not an exhaust leak? Either that or intake back fire?
Off topic: You have a closer pic of your avatar? You switched the A/C control yourself?
mustangsquared
828
new bern nc
May 5, 2004
  • May 5, 2004
It really sounds like something rattling around....I hope not a valve...but she idles well 99%of the time. What about the clutch pilot/throwout bearing...I have no play in my clutch cable (should I have any at the bell housing??) so I was thinking (yes, a very dangerous situation) that maybe I did not have enough pressure to keep the bearing from rattling?? If I am displaying HUA (Head up...) on this one let me know. I just filled up the tank with 93 oct and a bottle of Oct boost.
Off topic: I moved the AC/ Radio controls my self. Takes about an 1 1/2 hours. You will need a dremel and a radio install kit (the face plate to hide the AC contol cover panels curved edges after you cut an opening for the radio). Getting the AC/heater control vac lines to reach is a huge PITA...that will take up most of the 1 1/2 hours) I will try an post just the aviator later today if I get a chance.
mustangsquared
828
new bern nc
May 5, 2004
#10
  • May 5, 2004
  • #10
bump
SCORPION
386
Seaford, DE
May 5, 2004
#11
  • May 5, 2004
  • #11
does the clutch grind or rattle? I don't see why a throw out bearing would cause your knocking problems during acceleration, but sstranger things have happened
mustangsquared
828
new bern nc
May 5, 2004
#12
  • May 5, 2004
  • #12
The noise really is a thump/bouncing noise....like something is bouncing up and down. I thought maybe something broke and landed on a piston top. The only problem I see with that is that she runs great some of the time (since this started 2 days ago). I have clean oil/coolant (no mixing/cross contamination) No lose of quanity of either. Good oil pressure (@idle and high RPM), Temp is normal (between "L" and "A"). I am lost for ideas/solutions. Any more help/ what if's/try this/ would be appreciated.
dvs bullet
326
Ontario, Canada
May 5, 2004
#13
  • May 5, 2004
  • #13
Do you have the stock H-pipe in it ? If you do, sometimes the material in the cat will break lose and vibrate in the cat housing, it can come and go depending on if the material jams it self in one spot. I thought it might be a possability since the first cat on a stock sys. is right where you said the sound is coming from
mustangsquared
828
new bern nc
May 5, 2004
#14
  • May 5, 2004
  • #14
I have a BBK X pipe (w/cats)... never thougtht to ckeck it. I did tap on them and 1 sounded hollow, the other sounded full. I guess I will pull the pipe this weekend and take a look. I really do not want to have to "punch" them...then again it could help.
R
Rerun
312
South Bay, California
May 6, 2004
#15
  • May 6, 2004
  • #15
Any kind of smoke, even breif, when you start it?
mustangsquared
828
new bern nc
May 6, 2004
#16
  • May 6, 2004
  • #16
I get smoke from the back of the enigne....black... (not constant) today my check engine light came on for 30 secs and then went off. I think I see oil in my coolant can'tbe sure since it is too hot (and I am at work) to open the radiator up. This sucks...have to drive 300 miles tonight (round trip) to pick the wife up from the airport. She idles at 900 smooth with only a little "bump" in RPMS every 30-45 secs. Sound like a blown head gasket?? I am stating to get p!$$ed off. I take car of her and never go above 5400 RPM's (only on rare occasions)
mustangsquared
828
new bern nc
May 7, 2004
#17
  • May 7, 2004
  • #17
Update (for those that care/have helped): The smoke was a leaking trans seal throwing fluid on my cats/x pipe....
now for the thumping noise... drum roll please....
I had a collapsed cat...yes that right a collapsed cat. I sent 5 hours yesterday "knocking" both cats out ( broke a bolt on header...PITA). No more thumping sound...no more low end torque either. Check engine light came on again last night for 30 secs....still have no idea what is causing that.
Thanks for the help...
C
cbaker34
#18
  • Dec 6, 2007
  • #18
my 1990 lx 5.0 has the exact symptoms i will try the same this weekend
thx for the info.
SuperStang83
1,693
Boyertown, Pa
Dec 6, 2007
#19
  • Dec 6, 2007
  • #19
Thats ironic, but sometimes cats can lead to goofy problems that are hard to trace down.
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Fox Power Loss While In Gear
  • J_5.0_VERT
  • Dec 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2024
J_5.0_VERT
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
