  • 2005 - 2009 Specific Tech
numb steering? easy way to get better road feel
  • Thread starter Thread starter Matt Gruber
  • Start date Start date Oct 27, 2004
M
Matt Gruber
50
New Smyrna Beach FL
Oct 27, 2004
  • Oct 27, 2004
Cure:
remove the steering damper.(it's there to isolate the driver for a luxury car feel, but sport car drivers WANT road feel, at least i do)
SWortham
81
  • Oct 27, 2004
So you did this? Can you take a picture of the steering damper and where you removed it from? I'd like to see what you did.
And if you remove the damper, wouldn't it make the steering more susceptible to any imbalance? If so, you may have steering wheel vibration problems more often than you'd like. Just a thought.
M
Matt Gruber
50
New Smyrna Beach FL
Oct 27, 2004
  • Oct 27, 2004
yes i did this in 84 on a then new fiero.
you are right about bad balance showing up. i'd rather get a good balance than cover up a bad job.
i've read reports that the 05 stang has numb steering, and i know the feeling.(pun).
It looks like a shock absorber, attached to the steering.
It will steer easier and be less tiring without it. Pontiac agreed and eliminated it in '88.
I forgot to check when i tested the v6 yesterday.
SWortham
81
  • Oct 27, 2004
OK, good to know. Might be worth a try. I'd also try other things that could use upgrading anyways -- specifically, the tires. A stiffer sidewall should make a nice improvement in steering response. Maybe Yokohama AVS ES100's would do the trick. I haven't driven the car myself though so that would be the first step before I start making assumptions on what it's missing, heheh.
P
PONY XPRESS
143
  • Oct 27, 2004
Not sure I've ever seen a dampner on rack & pinion steering?
J
J98GT
185
Ann Arbor, MI
Oct 27, 2004
  • Oct 27, 2004
I don't know of any passenger cars built today that have steering dampers. Only recirculating ball steering systems really need them. I bet you could count on one hand the number of light duty vehilces that still have them . . .
wrangler, F150, Dodge Ram . . . Maybe the smaller trucks like ranger and dakota, but I think that's it.
On vehilces that use it, it's there for a reason. If your car uses one, leave it on. Period.
I know for a fact that no Mustang has had one at least since 87 . . .
SWortham
81
  • Oct 27, 2004
I wouldn't have known since I didn't really start to work under cars until after I owned my '97 Mustang. Well, tires may still be one of the best improvements you can make. That numbness could easily be coming from the stock tires.
M
Matt Gruber
50
New Smyrna Beach FL
Oct 28, 2004
  • Oct 28, 2004
J98GT
thanks! i called SVT and they did not know!
I wonder why the o5 is 88% stiffer than my 67? hmmmmm
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
