  • SN95 4.6L Mustang Tech
NX Kit not working... NEED HELP!!!
  • Thread starter Thread starter BuffMUSTANG
  • Start date Start date Jul 25, 2004
BuffMUSTANG
28
  • Jul 25, 2004
Ok, i had my NX kit hooked up and working about 2 months ago. It worked for the first 2 bottles. then i didnt use it for about a month. Just last night i had my bottle filled and went to use the nitrous but it didnt work. So my friend said that my FPSS doesn't do anything and that i didnt need it. So he bypassed the FPSS by putting both wires on one side of it. I went out and tested the kit and it worked. I put my spare tire and such back in my car from last night because i had it out for a weight advantage, i went out to test it again, it didnt work.... I dont understand. i didnt change or touch anything. What could it be? I was thinking either my WOT switch could have went bad or my Window Switch could have went bad. I checked all of the wiring and everything looks good. I'm just frustrated....
Cliff Notes: NX kit not working. What could it be? WOT Switch, Window Switch, Solenoids? Thanks...
BuffMUSTANG
28
  • Jul 26, 2004
sorry wrong forum... Should have been in the power adder forum... just seen that...
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jul 26, 2004
  • Jul 26, 2004
you need to test the solenoids , and get a test light and check all the switches also
BuffMUSTANG
28
  • Jul 26, 2004
Thanks very much for your input..... I was checking the wiring again and i didnt want to have to go back in to the passenger side kick panel to check the wire for the window switch but i figured if any wire was bad it would be the hardest to get to. So i checked that wire and found out that the connection was bad. I used an inline connector to get power from pin number 104 from the ecu. and connected the white wire from the ECU to the inline connector as well, but i used to big of an inline connector. So i bought the right size inline connector and it works just fine now. I also reconnected my FPSS. Thanks again....
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
gkomo
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
