- Jun 20, 2005
- 137
- 0
- 17
Ive been battling this problem for at least two years now, the o2 sensors are not doing their job. Between 1000-1500 rpms the car sputters and runs like crap under part throttle (anything above 1500 is fine, part throttle or wot) First of all, the car is a 96 gt supercharged with a saleen motor engine swap (01 s281) Around the time the swap was done, shortly afterwards, I installed a new h pipe and some bosh wideband o2s (i replaced them with brand new motorcrafts) Ever since putting in the new h pipe Ive had problems with the o2 sensors, though it was very shortly after the engine swap so that could have done it just as easy. According to the datalogs, the front o2s arent reading correctly, put in other words by my dyno tuner is they werrent heating up as they should. So Ive taken the wiring diagrams, done continuity tests from the front o2 sensor connectors to the pcm, I reflashed and reset my tune a dozen times, fixed the rear connectors so that they are plugged in and fine (though turned off in the tune) and of course I installed the brand new motorcraft sensors upfront. I even bought a spare pcm to try that out, with no results. I then turned to the grounds. First I rigged up my own ground right to the frame for the o2s as I read that someone tried this to fix a similar problem, but it didnt do anything. Found a disconnected engine ground strap, so I bought a new cable for that and installed it, surprisingly this did nothing... So she still sputters at low rpms, its sort of intermittent though. Such as, during really warm weather the car runs beautifuly, which makes sense I suppose as the sensors would heat up quicker in warm weather (with help of the exhaust of course). So here is what I need from you guys, ideas! This is the stupidest problem Ive had on this car, mainly because its such a simple circuit and it all checks out.. anyway, what other grounds should I check, and any bit of help would be awesome. I cant get the car retuned (successfuly) until those sensors work properly, but I might have to take a trip down there anyway. Thanks for the help guys!
