I put on an o/r X-Pipe and the front driver side o2 sensor is about 2" to short, Instead of buying a pair of o2 sensor externders how bad would it be to cut and splice the wire to extend?
You can extend the harness, but not between the sensor and the connector. The 02 sensor uses the insulation in that wire as a source of reference 02, which is needed to get good results - cutting it 'short-circuits' that...
Don
Don
