O2 Sensor Question/help
  • Thread starter Thread starter flashback87
  • Start date Start date Sep 8, 2014
flashback87
345
Cleveland, OH
Sep 8, 2014
  • Sep 8, 2014
I replaced the o2 sensors in my car about 2 years ago when i put in a 2000 explorer long block. I have been dealing with an idle surge this summer and have been through the suring idle checklist many times. the only codes i get are egr and emmissions related codes and i have no egr and all emission stuff has been removed.
The surge and idle quality acts up when the engine hits operating temperature.
So, i finally decided to try disconnecting the o2 sensors and driving around to see if that would make a difference. Well, it did. It idles great with no surge at all temps when they are disconnected. It even sounds better witht he cam being more pronounced.
So, my question is can 02 sensors go bad that quick? I have pulled the codes many times and their are no o2 sensor codes.
A little more info, last year the driver side o2 sensor wires melted on the header and it blew the inline fuse. i soldered in some new wire and put a blade fuse holder where the inline fuse was. it idled fine for a few months after that but started acting up this summer.
Thanks and any help will be greatly appreciated.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 9, 2014
  • Sep 9, 2014
Testing the O2 sensors 87-93 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear.
Disconnect the O2 sensor from the harness and use the body side O2 sensor harness as the starting point for testing. Do not measure the resistance of the O2 sensor , you may damage it. Resistance measurements for the O2 sensor harness are made with one meter lead on the O2 sensor harness and the other meter lead on the computer wire or pin for the O2 sensor.
Backside view of the computer wiring connector:
87-90 5.0 Mustangs:
Computer pin 43 Dark blue/Lt green – LH O2 sensor
Computer pin 29 Dark Green/Pink – RH O2 sensor
The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
91-93 5.0 Mustangs:
Computer pin 43 Red/Black – LH O2 sensor
Computer pin 29 Gray/Lt blue – RH O2 sensor
The computer pins are 29 (LH O2 with a Gray/Lt blue wire) and 43 (RH O2 with a Red/Black wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Testing the O2 sensors 94-95 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a red/black wire) and 27 (RH O2 with a gray/lt blue wire). Use pin 32 (gray/red wire) to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer. Using the Low Ohms range (usually 200 Ohms) you should see less than 1.5 Ohms.
87-90 5.0 Mustangs:
Disconnect the connector from the O2 sensor and measure the resistance:
From the Dark blue/Lt green wire in the LH O2 sensor harness and the Dark blue/Lt green wire on the computer pin 43
From the Dark Green/Pink wire on the RH Os sensor harness and the Dark Green/Pink wire on the computer pin 43
91-93 5.0 Mustangs:
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 43
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 29
94-95 5.0 Mustangs:
Computer pin 29 Red/Black – LH O2 sensor
Computer pin 27 Gray/Lt blue – RH O2 sensor
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 29
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 27
There is a connector between the body harness and the O2 sensor harness. Make sure the connectors are mated together, the contacts and wiring are not damaged and the contacts are clean and not coated with oil.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
Make sure you have the proper 3 wire O2 sensors. Only the 4 cylinder cars used a 4 wire sensor, which is not compatible with the V8 wiring harness.
flashback87
345
Cleveland, OH
Sep 9, 2014
  • Sep 9, 2014
Thanks, should the voltage test be done when the engine is at operating temp?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 9, 2014
  • Sep 9, 2014
Yes, with the engine running and properly warmed up.
flashback87
345
Cleveland, OH
Sep 13, 2014
  • Sep 13, 2014
ok, i tested the voltage on the 2 o2 sensor wires at the cpu when engine was warm. When i tested them, my voltmeter jumped from .o1 to .8 and it kept jumping around in that range. is that normal?
Thanks!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 14, 2014
  • Sep 14, 2014
Thanks!
That sounds about right. The low of .01 seems a bit off, But I think that it should work.
flashback87
345
Cleveland, OH
Sep 14, 2014
  • Sep 14, 2014
ok, now i need to test the connectors. I am hoping some one can give me some guidance on this. my probes on my multimeter are not long enough to reach to the 02 connector and to the cpu to test the resistance.
How do you guys do this?
Thanks in advance!
stykthyn
5,232
2,652
223
gainesville
Sep 14, 2014
  • Sep 14, 2014
May be kind of crude but perhaps run a length of wire from the o2 connector to where you can test the ecu.
flashback87
345
Cleveland, OH
Sep 14, 2014
  • Sep 14, 2014
would using a wire with an aligator clip as an exstension work? So, i would connect the alligator clip to the probe of multi meter and the other end of wire with alligator clip to whatever i use to probe the o2 connector.
would the readings still be accurate?
Thanks!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 15, 2014
#10
  • Sep 15, 2014
  • #10
Thanks!
That would work OK, just be sure that you have good, solid, clean connections.
flashback87
345
Cleveland, OH
Sep 15, 2014
#11
  • Sep 15, 2014
  • #11
In the instructions Above, the connectors to the o2 sensors are described ast "LH" and "RH". Can someone confirm if "LH" is passenger sid or driver side and if "RH" is passanger or driver side?
I aplogize for what is probaby a common sense question but i just want to make sure i did not switch the connectors when i installed the motor a while back and to make sure i am measuring the resistance between the correct wire and cpu pin.
Thanks!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 16, 2014
#12
  • Sep 16, 2014
  • #12
The point of reference is that you are sitting in the drivers seat facing forward. Right and left are viewed from that position.
flashback87
345
Cleveland, OH
Sep 16, 2014
#13
  • Sep 16, 2014
  • #13
Thanks! I tested the connectors with my multi meter set at 200 ohms and both read at 0.6.
What does this mean?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 16, 2014
#14
  • Sep 16, 2014
  • #14
I would think you got .6 of an Ohm resistance which for a length of wire and connectors is very good.
flashback87
345
Cleveland, OH
Sep 16, 2014
#15
  • Sep 16, 2014
  • #15
so it seems the voltage test and connector test both passed. i thought one of these would fail for sure since the car idles great with the o2 sensors unplugged but surges when they are plugged in.
Any other ideas or things i can try?
Thanks!
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 16, 2014
#16
  • Sep 16, 2014
  • #16
Just a stock long block, or have you got a cam in it?
Some cams just won't idle properly until you bump it up. I see a lot of guys having issues with the alphabet cams. I tried everything I could to get my Comp XE274HR to idle at near stock RPM and the ECU was having none of it. I'm now running around 800-850RPM on the stock tach and it seems to like that a lot better. It all but eliminated my surge.
Some of my issue I'm certain has to do with it needing a tune, but for the time being, bumping the idle is the fix.
flashback87
345
Cleveland, OH
Sep 20, 2014
#17
  • Sep 20, 2014
  • #17
Just to confirm, these test i did, does this confirm my o2 sensors are good?
It just seems odd because the idle surge stops when they are unplugged.
Thanks!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 21, 2014
#18
  • Sep 21, 2014
  • #18
Thanks!
With the O2 sensors unplugged the computer goes into limp mode, and runs on a fixed set of parameters that insure safe operation. With the O2 sensors working, it is in closed lop using all the available sensor inputs. Some sensor may be on the edge of going bad, but not enough to trip a code.
flashback87
345
Cleveland, OH
Sep 28, 2014
#19
  • Sep 28, 2014
  • #19
i've been doing some research on o2 sensor harness and cpu's but am a little confused. when i did my maf conversion i used a maf cpu out of an auto tranny car. my car is a 5 speed manual. so, i am using the 5 speed manual o2 harness from my 87 with a maf auto cpu. Is this creating issues?
I can still pull codes.
Thanks!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 28, 2014
#20
  • Sep 28, 2014
  • #20
Thanks!
No problems; I have run an A9P Auto trans Mass Air computer in my 89 5.0 5 speed. It works OK, and is my backup computer if I ever need one.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
