  • SN95 4.6L Mustang Tech
o2 sensors? needed?
  • Thread starter Thread starter gsvt
  • Start date Start date Jul 21, 2004
G
gsvt
51
dearborn, mi
Jul 21, 2004
  • Jul 21, 2004
Is it required to have o2 sensors? If you do not have any would the car run lean? btw, this is on a 99 4.6 saleen supercharged engine
thanks
T
TrueBlueCajun
208
Tampa, FL.
Jul 22, 2004
  • Jul 22, 2004
thanks
I think O2 sensors determine the carbon minoxide(sp) being expelled from your car. Technically you don't need them, but you'll have the nasty engine light on and you wouldn't know if something else is wrong with your car. Just get MILs and be done with it if you plan on going with an O/R Pipe. If you just want to unplug them from your cats...why do that?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 22, 2004
  • Jul 22, 2004
yes you do need O2 sensors. they moniter the air fuel ratio and you car will run like crap without them. they are required for any car with fuel injection or a feedback carb. you WILL fail emissions testing if you dont have them. and considering you have a saleen supercharged motor you would be a complete moron to not use O2 sensors.
now rear O2 sensors you can do without. all they do is moniter the efficiency of the catalytic converters. they were required as part of OBD2. however depending on where you live you will fail emissions for not having rear O2 sensors. you can get MIL eliminiators which mimmick the signal that teh rear O2's give to the computer, however those will also fail a good visual inspection.
Ryan02Stang
1,181
Arlington Heights, Illinois
Jul 22, 2004
  • Jul 22, 2004
YardSpecial
2,664
MT
Jul 22, 2004
  • Jul 22, 2004
Why in the hell would you take them off ???
O2's are your best friend and make tuning LOTS easier !
HuskerCobra96
741
Overland Park, KS
Jul 22, 2004
  • Jul 22, 2004
To add to the above post, you need functioning REAR o2 sensors for MIL Eliminators to do their job correctly. MIL eliminators don't replace O2 sensors, they piggyback and alter the signal, into fooling the PCM into thinking the cats are functioning correctly. You only need them if you are running no cats, or certain aftermarket catted race pipes.
O
Orange04BOSS
108
Denton, Texas
Jul 23, 2004
  • Jul 23, 2004
u definately need 02 sensors and also u might need some extenders. i just installed an offroad h pipe and i have an 04 gt. i got the h pipe from a guy with an 01 gt and the rear 02 sensor on the drivers side is too short to reach where they need to put in. i had to buy some extenders to make it work. but yes 02 sensors are a must if u wanna pass emissions.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
  • Gulftown980x
  • Jul 29, 2026
squeak93
