O2 sensors stuck
I am having problems getting the existing H-pipe out and not the problems I thought I would have (thought the extension I had for my impact wrench wouldn't get up in where it bolts up to the headers, all good there). I can't get the O2 sensors out . Is there something I need to do or just man up. I cranked on both of them and they aren't budging.
I think I got away with only removing the pass side O2 last time (I did the driver side with the H on the bench).
Very good idea with the PB blaster. I'd apply neverseize to the threads when going back on.
I find that sometimes a crescent wrench works best for breaking them loose - you dont have to worry about torquing the sensor at some goofy angle.
Good luck.
Another vote for using heat, but don't heat the O2 sensor directly. Heat the area around the O2 bung hole for 5 mins, spray it with PB blaster, then heat it again for another 2-3 mins. O2's should come right out with a standard 3/8" ratchet without any problems.
try heating it up with a t0rch and than using a small tea candle 0r whatever kind 0f candle y0u can find. heat the bung and than put the candle there and get the wax t0 g0 d0wn int0 the threads. w0rks like a charm and w0rks really g00d 0n header studs and really rusted up b0lts.
Yeah I was going to just remove the passenger side after I started having trouble. Thanks for all of the info. I'm going to go get a little torch and do the heat, sounds like it's most effective and time saving. Thanks.
