O2 Spacer or Mil eliminator???
hotstang
602
Tennessee
The other name for these are anti-foulers. They are available from your local autoparts store.
The PCM programming is smarter in later MY cars. Did you know in late model cars (2003 or 2004+) that the PCM will command a misfire just to confirm that the misfire is seen by the O2 sensors? That's why some simple MIL's might not work on a late model car.
Check out this post for information on why removing one cat could reduce the service life of the remaining cat.
http://www.stangnet.com/mustang-forums/threads/removing-2-cats.854444/
Interesting...
Thanks for the reply. I will eventually get a good high flow Xpipe with cats but just need to get thru emisions so I can transfer the title. They do the ODBII scan and dont sniff on newer cars so I should be good if I can get the light out.
So do you think the Anti-foulers or the MIL eliminator route would work better?
Thanks
