  • SN95 4.6L Mustang Tech
OBD2 car + OBD1 engine=?
  • Thread starter Thread starter jarod027
  • Start date Start date Nov 18, 2010
J
jarod027
  • Nov 18, 2010
Okay so here's the deal. I have a 97 mustang gt. 137k miles and leaking. So I just found a low mile, cheap, 94 mark 8 engine and want to swap it . The thing is, that engine is obd1 i believe, and my car is obd2. Is this swap possible within emissions? If so, what do I have to do to make it work? I live in Mass btw, fairly strick emissions testing.
N8Dogg98
3,872
238
184
MN
Nov 19, 2010
  • Nov 19, 2010
I have no idea. I'd assume the '94 Mark 8 engine is the same as the later Mark 8 engines, and therefore it should hook right up. Bill would probably know (LaserSVT) and I'm sure he'll show up here at some point, otherwise shoot him a PM.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 19, 2010
  • Nov 19, 2010
You may want to look into a 96-98 cobra engine swap , would probably be less painful to get the job done since most everything would be plug and play staying with mustang parts of the same year model
aar0s
1,015
55
69
Nov 19, 2010
  • Nov 19, 2010
nearly 100% that the mark 8 is odb 2, go for it.
GDawg
1,469
Nevada
Nov 19, 2010
  • Nov 19, 2010
If it's 94... then it's ODB I. And that engine is a 4 valve.
aar0s
1,015
55
69
Nov 19, 2010
  • Nov 19, 2010
huh, after a quick search of the interwebs i find that the 94's were 1's. when did they switch and wouldn't that be ideal for a 4v swap into a 79-95?
bhuff30
6,037
35
129
Olathe KS
Nov 20, 2010
  • Nov 20, 2010
The engine management isn't a big deal in my mind because you already have an OBD2 computer, harness and all the required sensors in your 97 GT. Worst case, you have to tap for some of the extra sensors. What is a big deal, is the fact that the intake on the mark 8 engine won't fit in the mustang. You will cobra parts from the intake up. Notice the throttle body is at the back of the engine on the Mark 8, it interferes with the firewall of the mustang. Also, keep in mind that you will need some sort of tune to run that engine effectively.
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
  • Gulftown980x
  • Jul 29, 2026
squeak93
Opinions on a possible project car w/ pics
  • Teen'93stang5.0
  • Mar 29, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Mar 30, 2026
Teen'93stang5.0
