occasional starting problem ??????
  • Thread starter Thread starter just4bob50
  • Start date Start date Sep 4, 2006
just4bob50
504
Pa.
Sep 4, 2006
  • Sep 4, 2006
I have been having an occasional starting problem that I havent been able to figure out. When the car starts like it supposed to it fires up on the first try, but when it doesnt it will crank over endlessly without trying to fire. Sometimes it will start on the 4th or 5th try and belch black smoke from the engine being loaded up from trying to start it so many times. Other times it wont start at all and when I come back to it a while later it starts right up no prob. It has happened on both the stock and Crane ignitions, stock and Accel coils, and 2 different coil wires. I hear the pump prime every time hence the engine getting loaded up with fuel. It does'nt matter if the engine is hot or cold, and one time when it happened at the wal-mart I was able to push start the car. Im out of ideas and I could use some help. thanks ahead of time.
just4bob50
504
Pa.
Sep 5, 2006
  • Sep 5, 2006
bump
50FoxBodyGT
74
Memphis
Sep 5, 2006
  • Sep 5, 2006
Hmmm, strange that the car would start at wal-mart by cranking the engine through a push start but not with the starter....
just4bob50
504
Pa.
Sep 5, 2006
  • Sep 5, 2006
everything is new as far as the ignition goes except for the dist. When my trans was busted I started the car to let it warm up twice a week. During the 2 months of down time it did it 2-3 times, and now 2-3 times in the last 2-3 days. Is there a relay or anthing else that could be failing. I dont care about replacing cheap parts. Are there any parts of the dist. that could cause this. I know this is going to get worse.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 5, 2006
  • Sep 5, 2006
Go through the checklist when it won't start...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 30-Jul-2006 to include 94-95 specific information
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. See paragraph 3A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
just4bob50
504
Pa.
Sep 8, 2006
  • Sep 8, 2006
Well i ended up tracking this problem down to the pick up coil in the dist. Thank to the info from Jrichker. Anyhow one morning it wouldnt start again so I pulled the dist. cap and there was a ton of dust and some moisture in it. After blowing out the dist. with an air gun it fired right up and started all day. I bought a pick up coil from Auto Zone, but couldnt get the dist. gear off the shaft. I went to 3 different garages to have some one remove it for me and none of them could do it. I asked them what would they do if a customer needed this repair done, and they said they would just put in a new dist. ( NICE !!!) So I guess I will buy a MSD pro billet dist. now since I was going to buy an HI-6R ign. anyways to replace my HI-6S.
HISSIN50
34
129
Sep 8, 2006
  • Sep 8, 2006
A bearing splitter can work for the gear removal. I'd also note that there's a specific tool for removing the gear. It's about 60 bucks as I recall.
just4bob50
504
Pa.
Sep 8, 2006
  • Sep 8, 2006
Yeah I found 1 online, but it was about 25 percent the cost of a new dist. plus the cost of the new pick up coil, and the fact that I would still have a stock dist. made me decide to buy a new one.
HISSIN50
34
129
Sep 8, 2006
  • Sep 8, 2006
Oh I hear ya bud. I was just posting info because I like the sound of my own E-voice. You chose to go a route that many many others do too.
vristang
4,933
101
124
Seattle
Sep 8, 2006
#10
  • Sep 8, 2006
  • #10
If you are still interested in getting the stock dist to work.
I have been able to remove the gears by tappin on them with a punch or blunted chisel.
Probably not the best way to remove a gear, but I was replacing it so I didn't care.
Putting it back on can be a little tricky, as you have to line up the stupid hole for the roll pin.
Wish you luck,
jason
just4bob50
504
Pa.
Sep 9, 2006
#11
  • Sep 9, 2006
  • #11
Wish you luck,
jason
A few years back my brother had to change his dist. gear to match the gear used on his lunati cam. He ended up beating the gear off and back on again but the hole wasnt lined up and he ended up taking it to a machine shop.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
