Odd Problem with Car
Kevin R.
473
Ohio
Today I was waiting in line for the car wash, when i got up to being the next person to go in the bay my car started to shake really bad. Never been to this carwash before so I wasnt sure what I was parked on i figured it could be something shaky, so as the door lifted I proceded into the wash, car feeling better.
Car feels normal while it is washing.
After the wash, the "Exit" light comes on and I put the car into drive. When I hit the gas, the car will not rev above 1500rpm and makes a "not-so-good-sound".
I turn the car off, disregarding the mass line of people waiting to enter, and then turn it on again. I hit the gas, only for the same thing to happen, car will not go above 1500rpm and will not move forward over the little blocker bump stop thing.
I do this a good 4 more times before my car muscles its way over this bump and out of the wash.
I immediately shut her off and get out, check my oil, push my plugs down, check coolant, check everything.
When i turn it back on it runs fine.
I went and got gas as a possible problem and it has run fine ever since i started it that last time..
Now I'm paranoid something is "secretly" broken only to come back as a bigger problem later.
Any ideas of what could have happened?
*cliff notes*
Car vibrated. Wouldnt go over 1500 rpm. Finally got it to go. Turned off. Turned back on and runs fine again.
:shrug: :shrug: :shrug: :shrug:
I know i always wash my own car. Nice day today after freeze yesterday, went out to turn the hose on and it was still frozen.
Plus its a "touchless" wash, know it isnt good for clearcoat but neither is a pound of salt stuck to my car. :)
Would low gas make it shake like that?
Possibly. It all depends on what's in the tank. If you have a lot of sediment/rust/something in the tank, you run that stuff through the engine when you get low on fuel.
I would suggest not letting the tank get below 1/4 tank. At least for a while. If the problem doesn't come back, you probably need your tank cleaned out. How much gas did you have when this happened?
