OEM 60mm TB & FRPP 65mm TB INFO
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
OK Guys
I've been going through a lot of old notes and trying to get stuff sorted and organized when I came across this info from some of my datalogs.
It is the difference of airflow between the stock 60mm tb and a 65mm tb with no changes other that the larger tb being installed.
Other than the diference in air flow, I know nothing about how much gain that additional airflow might be. :bang:
The data you see here is one data event from two different dlogs for each tb. The values hold pretty tight between each dlog so I think this stuff is valid for comparison.
Anyway, since we do have some brain trust peeps on this site, I thought maybe one of them might see this info and could convert the additional air flow to a ball park gain of some sorts. :shrug:
dlog# tb rpm kg/hr af ratio
1800 60 5800 778 12.43
2158 60 5950 780 12.46
1929 65 5850 805 12.33
2254 65 5950 805 12.49
Grady
