Off / on, OFF / on does it ever decide?
  • Thread starter Thread starter BK_CAULEY
  • Start date Start date Oct 3, 2007
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Oct 3, 2007
  • Oct 3, 2007
hey guys as some of you know i have been having issues with my 90 coupe but now i got a weird one.
here in the past few weeks it has been shutting off and NOT cranking back up.
EX: today i drove it around town for about 2 hours. was low on gas so i went to the service staton filled it up and it wouldnt start up. the last time this happened i move the car to cut grass and after moving it it wouldnt start back up. but in both cases after sitting over night they fired right up.
the first time it happened it ran for about 30 seconds so i dont think it is heat related but it might be. ive had TFI modules heat up go bad and make it run like crap but never not start up. Any ideas? let me her them . thanks in advance.
jake2582
107
tallapoosa
Oct 3, 2007
  • Oct 3, 2007
if i was going to throw parts at it i would start with a module.
Santeeford
27
San Diego
Oct 3, 2007
  • Oct 3, 2007
Have you checked fuel pressure when it is not starting. Ive had fuel pumps intermitently fail.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Oct 3, 2007
  • Oct 3, 2007
So it doesn't crank? If so look at your starter my friend. I had one that would heat up and crap out till it cooled down.
J
jerryD
1,061
Gladstone, MO
Oct 3, 2007
  • Oct 3, 2007
also check the relay on the fender. also check the wire going to the starter for corrosion.
ninety15.0
1,336
  • Oct 4, 2007
Also check to make sure you have a really good battery ground to the block. Make sure all your connections are clean and tight.
I also second the idea of the stock starters sucking when they get hot. You should really look into a PMGR starter from a 94-95. My car always starts when hot now. even with longtubes.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Oct 4, 2007
  • Oct 4, 2007
no guys it CRANKS fine. it just wont start back up. as predicted it started fine this morning. its weird. thanks for the suggestions though.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Oct 4, 2007
  • Oct 4, 2007
sounds to me like you are going to have to go through the dreaded crank but no startcheck list.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Oct 4, 2007
  • Oct 4, 2007
i try to but when i print it out go outside it starts up. so i cant never catch the problem. maybe my car is haunted
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Oct 9, 2007
#10
  • Oct 9, 2007
  • #10
well keep the print in the car along with your multi meter, code reader, some tools and do it when it happens.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Oct 9, 2007
#11
  • Oct 9, 2007
  • #11
glad you brought this back up. i have for the last few days and its happened everyday. i tried to crank it alot and started smelling gas kinda heavy. so i mash the pedal to the floor to cu tthe injectors off and after a few turns it starts right up. so i have found out its flooding down. thats why after sitting over night it fires right up.
so my next question is why does it randomly flood the engine down at start up? the ONLY codes im getting are EGR codes because of the explorer intake. im lost. and remember its only flooding out randomly. and everytime it doesnt start i imediatly hold my foot the floor and it pops.
R
robertdale
382
kentucky
Oct 9, 2007
#12
  • Oct 9, 2007
  • #12
I had an adjustable fuel pressure regulator that had a busted disk and it leaked gas into the intake while It was cranking. I would have to flood start often. I pulled the vac line that runs to the regulator and found gas squirting out full stream from the regulator.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Oct 9, 2007
#13
  • Oct 9, 2007
  • #13
i have a new regulator
JimBowy
330
Downriver, Mi
Oct 10, 2007
#14
  • Oct 10, 2007
  • #14
dude it sounds like a TFI module
my TFI didnt allow my car to start when it went bad... but every once in a while the car would still fire up....
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Oct 10, 2007
#15
  • Oct 10, 2007
  • #15
well it does it when the car is cold too. a TFI module will give you problems when the car is brought up to temperature. I THINK. but it is a point to check and thank you for your advice.
JimBowy
330
Downriver, Mi
Oct 11, 2007
#16
  • Oct 11, 2007
  • #16
the TFI can **** up when its cold too... its not a big deal to change up the TFI
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
