Off road H problem....
  • Thread starter Thread starter 89StangGT50
  • Start date Start date Dec 29, 2004
89StangGT50
178
TX
Dec 29, 2004
  • Dec 29, 2004
Im running into a problem installing an off road H on a 95 GT.
How do you get the stock pipe off since its welded to that metal hose that runs to the smog pump.
Rains
314
Chico, CALIFORNIA!!!
Dec 29, 2004
  • Dec 29, 2004
recipricating saw- i used my craftsman... sawed through it really quick
or take a blade from a hacksaw and spend 15-20 mins on it...
cut it at about where the new H pipe will connect to it
after new h pipe installed, connect the egr tube to the h pipe with rubber hose and either one or two hose clamps
good luck
you might even hjave to cut it 2 times... depending on how you angle it
89StangGT50
178
TX
Dec 29, 2004
  • Dec 29, 2004
Ok where can i get this rubber hose thats not going to melt?
281pony
2,681
Oly, WA
Dec 29, 2004
  • Dec 29, 2004
you can use pretty much any type of rubber hose. it doesnt see that much heat i dont think.
i used the same type of rubber automotive hose you can get anywhere. if your installing an offroad h-pipe maybe you should get rid of all your smog too and get rid of it all together?
Rains
314
Dec 29, 2004
  • Dec 29, 2004
i think i used a fuel hose?... i really dont know... any hose is ok ... just take a piece of the cut egr tube and run down to home depot or osh... get about 6" ... you will use about 1-2"
the hose will not melt. none/little heat
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Dec 30, 2004
  • Dec 30, 2004
The true stock setup is actuallyclamped there with a similar style clamp to a muffler clamp if I remmeber right. It's very small, but usually if you can get it undone, a little tugging will get the pipe seperated.
4dStang
Banned
Oct 23, 2002
718
Near St Louis, Missouri
Dec 30, 2004
  • Dec 30, 2004
I used silicone heater hose for the junction egr connection. The hose is expensive but can handle the heat. Used it many times with no problems.
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
