70mach03 said:2003 Mach 1. Just over 1000 miles. At or close to WOT, when shifting 2-3 between 5500-6000 RPM, it just "refuses" to go into 3rd. No grind or clunk , it just don't wanna go. Shifter feels kind of "soft" when it happens. No problems with 1-2. I really don't want to bring it to the dealer and give the tech a reason to beat on the car. Installed a Pro 5.0, seemed to help but, not eliminate the problem. It's frustrating as hell, cause otherwise this is an awesome car.
Jim
Angus said:I have the exact same problem.
Transmission was fine for ~ 1000 miles or so.
Now it won't go into 3rd gear over 5500 rpm 95% of the time - car has ~ 1700 miles on it today.
It's a shame really, because this tranny is quieter & smoother than the one in my '01 Cobra was...
White360RFnSwee said:synchros went bad around 4000 miles... my 2nd to third shifter is tough, and before I put it into reverse I need to put it into first or else it will grind
-Ryan
Jon Hale 2002 GT 27000 miles 2nd tranny.STANG07 said:JOHN BURLESON 2003 Mustang GT 2500Miles
jorge said:jorge lopez 1100 miles, FEARING THE WORST, but nothing yet. just hessitation going from 1-2 (like a bump) and tiny bit from 2-3
Mustang225 said:Been doing alot of reading here on dropping to 3.2 quarts but my mechanic spoke to Tremec and they won't warranty the tranny if there's a problem in the future.
jorge said:Jorge,
The original oil fill for a TR3650 was 3.8 liters. For 2004 the oil level was reduced to 3.2 liters for this transmission. This was done only after considerable testing. You can safely lower the oil level in your transmission to the 3.2 liter level. The only way to know you have 3.2 liters of oil is to drain the oil out and then add 3.2 liters. The reduced oil level should improve shift quality and keep the transmission cooler.
Our first choice of oil for your transmission is Dexron III ATF. The TR3650 was developed using this oil. We use Texaco Dexron III ATF in the factory for the original fill. It is very good oil at a reasonable cost. If you want to use a synthetic, use Mobil 1 ATF. Mobil 1 ATF is the only synthetic oil we recommend.
I hope this answers your question.
Best of Luck!
John Loeffler
i have a 2003 mustang gt. i just read a thread on some forum about this tranny. it wasnt good. but i got this info from it, (fill the tranny with 3.2l of some duratec stuff. coud u tell me exactly what i should fill this tranny with. im going to tell ford to do whatever u tell me in this e-mail your going to send me, cuz i dont want to be changing this tranny EVER. so please help me out before i damage it. the car has 1200 miles on it right now, but want to have 200000 miles on it before anything starts going wrong.
BTW i live in miami, kinda warm here year round.. anyways, i've found that by starting to shift to second before clutch is depressed makes it easier to shift and smoother (for whatever reason) but yea, when i go to my dealer, ima tell him about the 3.2l dexron stuff.
Mustang225 said:Are saying that John Loeffler is a service tech at tremec?
jorge said:The correct amount of fluid is the 3.2L and you should use Dexron III.
Jon A. Vieth
Product Line Manager
yea man, i went to tremec site. clicked to e-mail tremec and got two responces, one from product line managet and one from the other guy, dont knwo what he is but i could ask him... im guessing that it has to be someone in the know about tranny's??? i mean they wouldnt let just anyone answer would they ?
edit: clicked on tech@ ttcautomotive.com, im guessing this is tech and not some regular guy answering e-mails.
jorge said:well i dont care, im going to my dealer and demanding they do this, i cant wait till something starts going worng for anyone to do something about it. my dealer is scared that i call ford about ANY complaint, they went as far as tyelling me to fill out the service report thing where u rate ur experience in store. they want to make sure i mark everything perfect... so ima be like, u change this or get bad grades ******es
