  • SN95 4.6L Mustang Tech
offroad h-pipe
  • Thread starter Thread starter 2001GTTT
  • Start date Start date Apr 23, 2007
2001GTTT
12
  • Apr 23, 2007
I just bought a mac o/r h-pipe and cannot find a garage that will do it because it gets rid of the cats, i was wondering if this was something i could attempt on my own without much trouble? Thank you
:SNSign:
Miles
1,225
Burlington, ON
Apr 23, 2007
  • Apr 23, 2007
http://www.mustangworld.com/ourpics/fcar/hpip1.htm
Dope 97GT
439
Rochester, NY (SUNY Brockport)
Apr 23, 2007
  • Apr 23, 2007
yes its easy to do ive done it about 10 times now. You need to get a 1/2" ratchet with a long extension for the passenger side bolts then i get a adapter that goes from 1/2" to 3/8's then to a short extension and a swivel and then the socket for the nut. Be prepared to use some PB blaster and a breaker bar cause they are on there kinda tight.
When you put it back on tighten the passenger bolts as tight as you can because that is where the exhaust is gonna leak if there is one. Also remember to put the metal gasket back in too.
04DarkShadowGT
474
Fort Wayne, IN
Apr 23, 2007
  • Apr 23, 2007
Primarily the only places you can get to do o/r pipes is performance shops.
four six
506
Hobart, IN
Apr 23, 2007
  • Apr 23, 2007
+1 some states it is illegal for shops to install O/R pipes. Its not hard at all, you may also need a passenger side gasket for the header
F
flyboy86
94
Vance AFB, Enid OK
Apr 23, 2007
  • Apr 23, 2007
Be very careful when taking the bolts off the header. I was in a hurry with mine, I didn't let it cool down, and the stud sheared off. So now its gonna be a PITA to fix it. Just be careful.
G
GoBlue
40
Norfolk, VA
Apr 23, 2007
  • Apr 23, 2007
I agree, make sure that socket is on the bolt, or it will strip then your screwed. Happened to me.
Thats what made me buy headers.
MyBloodRunsBlue
127
  • Apr 24, 2007
yea you can attempt it yourself. you probably would want someone there to give you a hand especially since you'll be lying on your back doing the work. as they said let the bolts cool down properly so you don't strip one because then you will have to take it to a shop to get the sucker off. GL
2001GTTT
12
  • Apr 24, 2007
Thank you everyone.....id be F***** without you...lol. :SNSign:
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 24, 2007
#10
  • Apr 24, 2007
  • #10
Take your time, do your research first, use lots of PB Blaster.
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
  • Gulftown980x
  • Jul 29, 2026
squeak93
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
