oil capacity for 94 gt
Guys!! Come on now, everybody knows the easiest way to change the oil is to drop the oil pan. That way you get ALL the old oil out!
OR..... you could just drop both plugs and run the motor for a few minutes, that'd be sure to get it all out. :D
you could always drill and tap two new drain holes if you dont have the proper tools to get the existing plugs out. another option would be to use a punch instead of a drill sence it would help create some extra threading material and then tap it. :D
