Oil capacity?
  • Thread starter Thread starter 50Pilot
  • Start date Start date Sep 27, 2009
50Pilot
Auburn,WA
Sep 27, 2009
  • Sep 27, 2009
I probably look like numbnuts over here, but i just flipped through my owners manual and couldnt find it. Im told it was 5 and 6 and now im stuck in the middle, im gonna be running a quart of stabilizer too so i dont know if that counts as a quart of oil or not. So what the hell is it? lol
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,081
224
Massachusetts
Sep 27, 2009
  • Sep 27, 2009
I dunno. What do you drive? A yugo?
And yes, a quart of stabilizer counts as a quart towards total capacity. If you add 5 quarts of oil and a quart of stabilizer, you now have 6 quarts in your pan and you are overfilled.
BTW a typical 5.0 takes 5 quarts..but no idea if this is what you were asking for.
50Pilot
Auburn,WA
Sep 27, 2009
  • Sep 27, 2009
well yeah my 87 lx notch with the 5.0. i wasnt sure
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Sep 28, 2009
  • Sep 28, 2009
Yep it is a 5 Quart capacity, not sure what you mean by stabilizer, but I would avoid additives in the oil.
CobraGT89
Cleveland OH
Nov 1, 2009
  • Nov 1, 2009
Hey guys not sure if this thread is dead.
I changed my oil and was reading more than full at 4 quarts ( past the full cross hatch marker on the dipstick) For the sake of caution I didnt add the 5th quart, I was afraid of blowing my seals.
Now about a month later still reads full but check oil light is coming on.
Just to double check, I check oil level when engine is cold right? 5.0 302 calls for 5 quarts?
I just checked my oil again it was reading a quart low, I added a quart and now I'm what looks about a quart past full again. The check oil light did go out though.
Total amount of oil is 5 quarts, the one I just added was the 5th from the oil change.
Any advice is appreciated, Thanks.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Nov 1, 2009
  • Nov 1, 2009
These cars take 5 quarts. Add 5 quarts, drive the car around, wait for it to cool down then check the dipstick. See where its at and make a mark there. That IS your fill line. Just make the mark with a razor blade.
1991notchbackLX
1,483
47
48
New York
Nov 1, 2009
  • Nov 1, 2009
Fox Mustangs have a double hump oil pan from the factory. Did you pull both the front and rear drain plugs when you drained the oil? If you only drained the rear you could have left up to a quart of old oil in the front sump. Just FYI.
CobraGT89
Cleveland OH
Nov 1, 2009
  • Nov 1, 2009
Yeah I pulled both plugs, front and back. Not much drained out of the front though.
So at the next oil change I'll add all five start it up and let it circulate. Once it cools off make my new full mark with a razor.
Thanks for the help guys, really appreciate it.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Nov 1, 2009
  • Nov 1, 2009
I coulda swore when looking in the catalog at my work it said 4 quarts but they may have been w/o a filter. I always use 5 though.
EDIT: ah yes that is w/o filter.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 2, 2009
#10
  • Nov 2, 2009
  • #10
The Service Manual says that the Oil Level will read above the Full Line, not sure why they just did not mark it properly in the 1st place.
k4mjk
49
North East Georgia
Nov 2, 2009
#11
  • Nov 2, 2009
  • #11
if you check it when its running it is right
Blucifer99
I only understand every 3rd word
Jul 15, 2018
466
31
38
Port Mcnicoll Ontario
Jul 20, 2018
#12
  • Jul 20, 2018
  • #12
can any of you guys give a straight answer without rambling off about the trees or some other S**t... How many quarts does a 5L oil pan hold... is it 5 quarts or 6 quarts or 4 quarts? How many F****n quarts???????
Like comon man a simple answer is perfect no need for the psycho babbling....
so How many quarts does a 5.0L take without a filter change and how many quarts does a 5.0L take with a filter change... short answers only
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 20, 2018
#13
  • Jul 20, 2018
  • #13
Oil capacity with stock oil pan is 5 quarts including the filter. At least 3 people have already said that...
When you change the oil be sure to remove the drain plugs and drain both front and rear sumps.
The dipstick is a bigger liar than most fishermen that I have met.
Drain both front & rear sumps, put the drain plugs back in. Then change the filter and add 4 quarts oil. Start the engine and let it idle 2 minutes or so. Shut it off, wait 2 minutes for the oil to drain back into the pan. Pull the dipstick out, wipe it off and stick it back in. Pull it out again and take note of the oil level. I marked the dipstick with a scratch from a file at the 4 quart level.
Add the 5th quart, start the engine and let it idle 2 minutes or so. Shut it off, wait 2 minutes for the oil to drain back into the pan. Pull the dipstick out, wipe it off and stick it back in. Pull it out again and take note of the oil level; it won't be anywhere near the factory full marks. I marked the dipstick with a scratch from a file at the 5 quart level, which is about 1" above the factory full mark.
General karthief
Mod Dude
Aug 25, 2016
28,100
10,714
213
polk county florida
Jul 20, 2018
#14
  • Jul 20, 2018
  • #14
Nov 2, 2009
#11
Check the date stamp in the upper left corner before you go off on a tangent, and lighten up a bit, this stuff can be fun if you let it roll.
JD1964
there is enough sticking out to grab on to
3,549
1,598
194
Maryland
Jul 20, 2018
#15
  • Jul 20, 2018
  • #15
I concur the factory dipstick marks are wrong many times. I had to remark both my 92 and 93. Each one now has a new mark almost an inch above the factory marks. If I'd have kept paying attention to the factory marks, I'd be running around a qt low. Before I fixed the mark position, I'd get the low oil light occasionally even though the oil was showing full according to the incorrect factory mark.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 10:46 PM
Blackhawkxx
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
