  • SN95 4.6L Mustang Tech
Oil change disaster
  • Thread starter Thread starter Stang2003GT
  • Start date Start date Jan 24, 2004
1 of 2 Next Last
Stang2003GT
254
  • Jan 24, 2004
So this morning I get up and change my oil to 6quarts with a fram filter. Drove it for about 10 miles then the service engine light came on. So i pulled over checked my oil and everthing looked fine. I got home and disconnect my battery and it work but after 5 mile the light came back on. Now ive had a prochamber for about 1 month with the O2 sims and never had a problem till today. What could of happend? I didnt touch anything else. Im afraid to take it to ford and it was so hard to get the pipe on and i dont want to pay the same guy 80 to put the stock back on just to have ford look at it. I bought the O2 sims at Rpmoutlet. Please help Im so mad i only got 9000 miles on the car.
KaPPaBaLL
1,326
BAYAREA
Jan 25, 2004
  • Jan 25, 2004
why'd you title it oil change disaster if you don't know if it's the oil change that actually caused this?? anyway, go to autozone and pull the codes and see what they are. Come back with the codes and post it up. BTW, 6qtz is a bit much. 5 is sufficient.
SVTSTEEDA
181
Greensboro NC
Jan 25, 2004
  • Jan 25, 2004
maybe a wire or connection was pulled somewhere? like they said get codes pulled and post. hopefully it's something simple.
P
Pootiestang
That's MISTER boy to you!
3,835
Sav, Ga
Jan 25, 2004
  • Jan 25, 2004
Carefull, I went to Autozone and they told me I was having converter problems....Right My 5 speed needs a new torque converter.....
Maybe that extra quart is causing it?
stangman
2,690
10
69
in a 3 bed, 2 bath
Jan 25, 2004
  • Jan 25, 2004
ya think they meant CATALYTIC (sp?) converter. cause i really don't see them being that dumb of course i've heard of stranger things
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Jan 25, 2004
  • Jan 25, 2004
Hmm.. on the manual it said 6 qts. Mine is right on the good spot around 5.5 - 6 qts
Go to autozone and get you code check.
gtrackd02
290
st clair shores
Jan 25, 2004
  • Jan 25, 2004
our cars are suposed to have six quarts of oil in them......... At least thats what my manual says. I do agree , go somewhere and have them pull the codes....
P
Pootiestang
3,835
Sav, Ga
Jan 25, 2004
  • Jan 25, 2004
I know what he may have meant but the guy said torque converter. Im just saying becareful on what they say.
01'TRUE BLUE GT
4,984
Pittsburgh, PA.
Jan 25, 2004
  • Jan 25, 2004
No wonder you titled this "oil change disaster" ... you used a Fram filter! Not that it has anything to do with your problem, but that's the worst filter money can buy, in case you didn't know.
KaPPaBaLL
1,326
BAYAREA
Jan 25, 2004
#10
  • Jan 25, 2004
  • #10
all manuals are different.. mine says 5qtz
lopey4.6
20+ Year Stangneter
Jan 4, 2004
309
Westlake,OH
Jan 25, 2004
#11
  • Jan 25, 2004
  • #11
FRAM OIL FILTERS
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Jan 25, 2004
#12
  • Jan 25, 2004
  • #12
What he (smart dude ) said. Fram = jizzunk. The motorcraft "820S" oil filter is the way to go...
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jan 25, 2004
#13
  • Jan 25, 2004
  • #13
My 02 GT says 5 qts in manual and ive checked it and double checked , my brothers 03 F150 4.6 holds six , and his manual says six , ive looked at both oil pans , they look the same , i pulled his dipstick and its shorter so his doesnt read full till you put six in it , makes ya wonder huh . Every mustang I have ever seen and I used to work at an oil change station , held 5 qts . But to me the only difference ive actually seen is in the length of the dipstick , so I dont guess its that big a deal . As for the check engine light , take it back and post the number of the code , I am sure someone here might be able to give a better explanation of it . If you dont have converters and have not installed MIL eliminators its probably that . It will read that the back converters have not reached proper operating temperature because the exhaust is flowing much faster and disipating the heat through the tail pipes better . I had my off road Hpipe on for a week before it triggered the light . Then I broke down and spent the money on the MILs .
2K1GtfromSC
705
West Columbia, SC
Jan 25, 2004
#14
  • Jan 25, 2004
  • #14
My 01' Gt was 5 qts & my Cobra is 6 qts.
You probably just need new mil eliminators. Some people have had problems with mils going out. Is the MacProchamber a O/R x-pipe? I have only had Bassani so I'm not sure about the Mac. I used Dallas Mustang for the Mil Eliminators.
John
ShadowGT
202
Western Kentucky
Jan 25, 2004
#15
  • Jan 25, 2004
  • #15
I agree, sounds like your mils went bad and it just so happened you had just changed the oil.
To address the oil capacity issue, Ford changed the capacity, and I assume the oil pan in mid 2002 (I believe). My 2003 holds 6 and the manual recommends 6.
I'm sure if you do a search you can get more info.
FYI, the new GT's will also have a 6 qt capacity.
StangClear
112
Elkton, MD
Jan 25, 2004
#16
  • Jan 25, 2004
  • #16
I have an 03 GT and the manual says 6 quarts. And with 6 quarts and filter it still doesn't come up to the full line on the dip stick. About three quarters of the way. So who knows...............
krly79
464
VA Beach & So Illinois
Jan 25, 2004
#17
  • Jan 25, 2004
  • #17
There was a TSB released on the oil dipstick markings being off. Check out alldata for the details.
FireChickenRacn
12
NAF Atsugi
Jan 25, 2004
#18
  • Jan 25, 2004
  • #18
why is fram bad??? ive always used them with the exeption of the time i used a k&n and havent had any problems with either oil filter?
Stang2003GT
254
#19
  • Jan 25, 2004
  • #19
Ok so tomarrow im going to get the code checked and ill post it. I heard that FRAM is suposed to be best filters. They last longer and filter to a smaller degree. Also is it dangerous for me to be driving around with the computer having an error cause if the computer reads a low exhaust gas temp wont it lean the mixture and if it leans the motor when its not supposted wont that create a detonation problem?
spree
294
los angeles
Jan 25, 2004
#20
  • Jan 25, 2004
  • #20
yup, 2003's take 6 quarts. My dipstick wasn't anywhere near the maximum after 6 quarts...it was about halfway up.
1 of 2 Next Last
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
squeak93
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
Looking forward to collaborating with my new community
  • phil2001svt
  • Sep 24, 2026
  • The Welcome Wagon
The Welcome Wagon Saturday at 10:49 PM
phil2001svt
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
