Oil change question
  • Sponsors(?)
zookeeper
3,338
48
109
58
Rogue River, Oregon
I use Valvoline 20-W50 VR1 since it has zinc. My engine only has about maybe 5K miles on it, I change it once a year (maybe 800 miles) and it doesn't use oil, slow any signs of trash or cause any other problems. I live in Southern Oregon where summer temps get 100+ daily and my car sees a good mix of freeway and city, even though it's limited mileage.
08GT500
771
111
53
Massachusetts
Hi,
Simple answer for a change: Viscosity, 10-40 in the Summer, 10-30 in the Winter (if it’s driven, then). High mileage, Conventional. Penzoil High Mileage.
Run an HDDP Additive within the Oil.
Never go above 15/50Wt.
OE Filter, K&N, Mobil 1, etc.
You’ll find everyone has they’re own Oil preference, & despite the question is simple, answer is much more complex. I’ll explain.
Guessing this is relatively stock & you’re running a Flat Tappet Hydraulic, or Solid Cam. Not a Roller Cam-correct?
Do you have a Mech. Oil pressure Gauge?, if not, I’d recommend installing one.
Motor’s needs for Oil Wt. of is a combo of Both OE recommendations & Specifics of your engine & how it runs.
If you start it up after 24Hr’s & Hydraulic lifters clack away for a few minutes upon startup, low Oil Pressure at Idle when Cold, jump up a viscosity grade. Not more viscous than necessary, the components within the Oil are of equal importance.
Viscosity and Oil Type is Based on:
1) Bearing clearance setup. Mains-Rods.OE, or rebuild spec’s.
2) Achieving >/=25PSI at Idle, then 10psi pressure per 1,000 RPM up to 5,000 RPM’s, 50 psi.
3) What Oil type has been run in it, how often was it changed. Was it already converted to a Synthetic blend after the Rings were seated?
4) Mileage.
Independent of ANY of the above..
I’ve run ZDDP & Zinc additive(s) ever since ZDDP levels began to decline, flat Tappet Cam’s require minimum levels of ZDDP.
ZDDP has been an important additive to engine oils for >70 yrs, has an excellent track record at protecting the sliding metal-to-metal cam lifter interface by creating a film on cams and flat lifter contact points in response to extreme pressure and heat.
The film of zinc and phosphorus compounds provides a sacrificial wear surface protecting the base metal of the cam and lifter from wear. They’ve been removing it for Cat’s protection, large duration between Oil changes.
Synthetics are worth it if you have a strong, high mileage Motor, it’ll halt wear in the 90% range.
Some older, high mileage Motors May burn Oil as result of it, or old Seals May leak. It may be run providing the Viscosity and HDDP levels are present. If the Motors been taken care of across its miles, good Oil Pressure, no leaks, then it’s worth considering.
-Pennzoil is great, has adequate levels of HDDP, Detergent, Full Synthetic, Detergent type, HDDP is adequate, it’s made for High Mileage app’s. .
- Mobil 1 High Mileage Synthetic, 15-50 Wt. is required to get the HDDP levels, designed for high mileage, Detergent.
My OWN preferences:
- Amsoil or Valvoline, Quaker State, Pennzoil are what I run for Conventional Oil’s.
- Ford has their own Synthetics, I run that, Mobil 1, Royal Purple, Valvoline, Pennzoil for Synthetic Oil’s.
Run an OE Filter, Or K&N, Mobil 1. Makes no difference regarding Conventional or Partial/Full Synthetic Oil’s
Sorry for the dissertation, but there’s a lot to the subject, Type in Zinc, HDDP, view the importance in older app’s.
If you have any questions about anything I’ve listed, please- feel free to ask!
- John
Thread starter Similar threads Forum Replies Date
from6to8 Want To Change Out The Oil Tube..............few Questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
oneslowgt Another Oil Change Question Xd 1994 - 1995 Specific Tech 5
littlechief0 1st oil change on my new 2001 Cobra. Oil questions. SVT Tech Forum 8
85_SS_302_Coupe Funny oil change question Fox 5.0 Mustang Tech 8
62thunderbird Changed oil but have a question need help! 1996 - 2004 SN95 Mustang -General/Talk- 3
00stangv6lr Quick Oil change question SN95 4.6L Mustang Tech 5
K Oil Change Question 2005 - 2009 Specific Tech 12
J Oil Change Question SN95 4.6L Mustang Tech 14
bullitt_2620 Changing tranny oil questions SN95 4.6L Mustang Tech 27
J changed plugs and oil, have some questions. Fox 5.0 Mustang Tech 5
Mustangless oil change question 1994 - 1995 Specific Tech 3
BigChiefSmokem Oil question: How long in between oil changes SN95 4.6L Mustang Tech 18
Rynb15 Question on oil change........ Fox 5.0 Mustang Tech 20
L Oil Pan Gasket change question 1994 - 1995 Specific Tech 6
C Seafoam and oil change questions... 1994 - 1995 Specific Tech 2
K Changing my oil myself, few quick questions. SN95 4.6L Mustang Tech 28
C Oil Change Interval Question??? SN95 4.6L Mustang Tech 4
Pearl02 Stupid Oil Change Question SN95 4.6L Mustang Tech 16
G First oil change questions SN95 4.6L Mustang Tech 15
91LX_5L Oil Change Question - What Oil and Filter do YOU use? 1994 - 1995 Specific Tech 28
SonicBlue2v03GT Question - Has anyone changed weight of oil after Supercharging?? SN95 4.6L Mustang Tech 1
1 Oil change question.....sorta. SN95 4.6L Mustang Tech 10
Restomod 67 C4 oil change question Classic Mustang Specific Tech 3
LouisianaZJ Oil Change? a few specific questions SN95 4.6L Mustang Tech 14
swingline Stupid oil change question... 1994 - 1995 Specific Tech 12
S 98 gt oil change... stupid question SN95 4.6L Mustang Tech 13
LILCBRA Oil pan gasket change OR starter replacement in a 302 II 1974 - 1978 Mustang II Talk & Tech 4
92j3ieje8 How many miles is an oil change needed for a v6 o4 mustang? 1996 - 2004 SN95 Mustang -General/Talk- 0
A Auto Transmission oil change. 2015+ (S550) Mustang -General/Talk 3
R Fox oil change 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
C 98 GT - Don't see oil level on the dipstick after an oil change SN95 4.6L Mustang Tech 2
E Oil change for modify GT SN95 4.6L Mustang Tech 2
M Please Help and Advice The Welcome Wagon 4
0 03 Mustang v6 .....Rpm dropping/ New oil Change SN95 V6 Mustang Tech 0
1 Engine 1995 Mustang GT 1994 - 1995 Specific Tech 0
Blucifer99 Engine 1992 mustang oil pan capacity with and without filter change Fox 5.0 Mustang Tech 22
D First oil change? 2015+ (S550) Mustang -General/Talk 10
GrandmasterK Check Oil Light After Oil Change Fox 5.0 Mustang Tech 5
EXTRPR50 Oil Change Mess! Wth?? 2005 - 2009 Specific Tech 7
Sketchy_GT Oil/oil Change Fox 5.0 Mustang Tech 24
Debrajean70 Check Engine Light On 2004 Stang Gt With Low Milage!! The Welcome Wagon 5
D Installing Mgw Shifter And Changing Trans Oil. Can I Do It In My Garage? 2010 - 2014 Specific Tech 6
NJBob Oil Change Indicator 2015+ (S550) Mustang -General/Talk 8
KENS89LX Changing Oil Cooler Adapter Gasket SN95 4.6L Mustang Tech 6
NJBob Oil Change - Does Ford Plug In 2015+ (S550) Mustang -General/Talk 3
O Change Out Distributor Now The Oil Pump Not Working 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Still Bill First Oil Change 2015+ (S550) Mustang -General/Talk 7
M Engine No Oil Pressure 5 Min After Oil Change SN95 4.6L Mustang Tech 5
newedgejay Oil Change. SN95 4.6L Mustang Tech 7
8 Water In Oil After Intake Manifold Gasket Change Fox 5.0 Mustang Tech 4
