wow....two oil pan plugs,one forward, one aft, look under there, you'll see em, I use, just from personal preference, Pennzoil 10w30, 5qts....are those bottles 5qts?... thought they were 4, and a Motorcraft filter, fl18a, think that's the number. When you take off the filter make sure the o-ring comes with it, if not just peel the old one off. I like to fill the new filter up bout half way, any more seems to spill when trying to thread it on. And wet the new o-ring with fresh oil, keeps it from tearing when it starts gettin tight. I just put my filters on hand tight. Nothing specail bout removing the filter, may need a filter wrench, if you don't have one/know what it is, just ask the parts store clerk or match it up to your new filter, prolly be in the same section as the oil. let it run for a while (fills up the filter) then top it off...good luck with it that's what I do
