  • 1994 - 1995 Specific Tech
oil change
  • Thread starter Thread starter trelz4
  • Start date Start date Sep 15, 2005
T
trelz4
38
decatur,illinois
Sep 15, 2005
  • Sep 15, 2005
i just put a gt40 motor in my mustang the way it is set up i cant use the oil fill tube the mechanic said just to pull the pcv valve in the back of the plenum and fill it there is this ok?
95COBRA241
339
Delray Beach, FL
Sep 15, 2005
  • Sep 15, 2005
Yes but pls explain why you can't add oil the conventional way.
HISSIN50
34
129
Sep 15, 2005
  • Sep 15, 2005
Wow.
It would almost be easier to pull the dizzy.
I would be tapping a VC, etc to make this happen easier.
CManT1914
3,172
Killeen, Texas
Sep 15, 2005
  • Sep 15, 2005
We all know the easiest way to change the oil is to pull the motor out and take off the oil pan!!
DarkProphet
391
Quakertown, PA
Sep 15, 2005
  • Sep 15, 2005
You damn near have to on a lowered car. The front plug isnt hard to get to, but that back one is a pain!
legalize420
1,541
South Florida
Sep 15, 2005
  • Sep 15, 2005
why would you say that? if you can get the jack under there then there is no reason you cant get it to the same height as a non lowered car. put the jack on the k member and you will have more than enough room to get to the back plug.
DarkProphet
391
Quakertown, PA
Sep 15, 2005
  • Sep 15, 2005
Jack doesnt fit under the car haha, I have to drive up on 2x4's first...
T
trelz4
38
decatur,illinois
Sep 15, 2005
  • Sep 15, 2005
the way the tb comes off the manifold it runs right where my oil filler was we had to plug it with a pcv and then he said to fill it in the back, not hard to get to i just wanted to make sure this was ok thanks for the info btw if i tap the vc then what would i do just put a rubber grommet in the hole? and if so would the passenger side vc be ok?
95COBRA241
339
Delray Beach, FL
Sep 15, 2005
  • Sep 15, 2005
Why not try a non EFI vc w/o the tall filler neck? Then you would able to use a regular oil cap
T
trelz4
38
decatur,illinois
Sep 15, 2005
#10
  • Sep 15, 2005
  • #10
thank you ill give that a shot
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 15, 2005
#11
  • Sep 15, 2005
  • #11
or you could install an oil filler on the other valve cover. That would work. Trick flow sells a nice one.
Doing it through the PCV wouldn't be that bad. Just get a funnel with a tube on it. No problem.
Scott
Methodical
1,192
11
59
Clinton, MD
Sep 16, 2005
#12
  • Sep 16, 2005
  • #12
My MAC CAI comes slighter over the oil filler hole because of the angle of the TB. However, I am still able to get the oil cap on. But I just unhook the clamp and hose at the TB, change the oil, then reinstall.
Are you at least able to get the oil cap on. If so when you change the oil just do as I said above. Not that difficult. Just One Man's Opinion. Peace
T
trelz4
38
decatur,illinois
Sep 16, 2005
#13
  • Sep 16, 2005
  • #13
I Cant Even Get Close To The Hole My Tb Is Over It I Have A Trick Flow Track Heatwith Sn95 Adapter A C & L Cai 65 Bbk Tb That Sits Right There Thanks For All The Input
CManT1914
3,172
Killeen, Texas
Sep 16, 2005
#14
  • Sep 16, 2005
  • #14
Ever heard of a "."?
Hope something works out for ya.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
