i just put a gt40 motor in my mustang the way it is set up i cant use the oil fill tube the mechanic said just to pull the pcv valve in the back of the plenum and fill it there is this ok?
CManT1914 said:We all know the easiest way to change the oil is to pull the motor out and take off the oil pan!!![]()
DarkProphet said:You damn near have to on a lowered car. The front plug isnt hard to get to, but that back one is a pain!
trelz4 said:the way the tb comes off the manifold it runs right where my oil filler was we had to plug it with a pcv and then he said to fill it in the back, not hard to get to i just wanted to make sure this was ok thanks for the info btw if i tap the vc then what would i do just put a rubber grommet in the hole? and if so would the passenger side vc be ok?
trelz4 said:I Cant Even Get Close To The Hole My Tb Is Over It I Have A Trick Flow Track Heatwith Sn95 Adapter A C & L Cai 65 Bbk Tb That Sits Right There Thanks For All The Input
