  • SVT Tech Forum
Oil cooler blew out, and ford doesn't have them anymore!
  • Thread starter Thread starter mustang_jr+
  • Start date Start date Dec 19, 2010
M
mustang_jr+
150
Dec 19, 2010
  • Dec 19, 2010
Any ideas? 96 cobra. My business is slow right now, so I can't blow $400
on something crazy. Ideas?
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Dec 19, 2010
  • Dec 19, 2010
The entire oil cooler went south or what specifically went bad ? Maybe just an o-ring or gasket ?
If you do have to replace the entire unit, try some other places besides the dealership (like our classified section or other various internet based Ford parts websites).
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 20, 2010
  • Dec 20, 2010
The oil cooler O-ring is bad about going out. The oil cooler can be fixed in many cases by replacing the O-ring and the block to oil adapter gasket.
The O-ring is a Ford part (very large), but the oil filter adapter gasket is available from your local autoparts store.
Drain the coolant. Remove the oil filter. Remove the large Allen bolt through the center. This will give access to the filter to block adapter bolts.
Be sure to change the oil once everthing is back together.
M
mustang_jr+
150
Dec 20, 2010
  • Dec 20, 2010
Looks like for some reason there was a hole in it. Welded and it's fine now.
unrelated, my control arm is bent. So much for tubular arms...
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Dec 21, 2010
  • Dec 21, 2010
mustang_jr+ said:
...Looks like for some reason there was a hole in it. Welded and it's fine now...
Ahhhh!
The hole you welded up was probably a weep hole....AFAIK, it's supposed to be there.
Unless you got pics to prove you possibly cracked the oil cooler assembly or it somehow rotted through and/or developed a hole ?
M
mustang_jr+
150
Dec 21, 2010
  • Dec 21, 2010
So the inside there's some o-rings that are bad, I can't get them from the dealer.
A new cooler is something silly like $330.
I need a rebuild for the cooler internals (there's a cartridge thing with the rings) or
some other solution.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 22, 2010
  • Dec 22, 2010
The oil cooler can be deleted. Use a standard GT style Romeo oil filter adapter.
Most Mustangs don't have oil coolers anyway. Ford dropped them because they aren't really needed and they leak alot.
That's odd that Ford does not have the O-ring. When I rebuilt mine, the replacement O-ring came from Ford.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Dec 24, 2010
  • Dec 24, 2010
Burns, where have you been, miss you in the SN-95 tech, come back and school these fools.
Yea, what burns said, the oil filter adapter has a gasket which makes the filter look like its leaking at times, both coolant and or oil.
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
SN95 V6 Mustang Tech May 22, 2026
PNN
P
  • SVT Tech Forum
