same length as for a 302 or 289. the easiest way to mark one though, if you got an aftermarket stick that is cut to length, is to fill the pan with three qts of oil, then mark the stick at the qt low level, then add the fourth qt of oil and mark the full level. then cut the stick about 1/2" below the qt low mark.
