oil going up pressure gauge hose
Huh? The line on a mech OP gauge is to supply the gauge with pressurized oil.
Be sure to install a restrictor in the line in case it ruptures. A metal or braided line is a good upgrade over the nylon line.
Good luck.
Original post before the edit:
Just tried to install a mechanical oil pressure gauge and having a problem.I put a tee under the oil pressure sender and attached the other end to the vacuum hose that goes to the gauge. The problem is that the vacuum hose going to the gauge is sucking up oil.
Good luck.
A better option if the gauge is installed in the interior would be to run an isolator, so no hot engine oil runs into the passenger compartment. They do tend to be on the pricey side, however. I think that's why most end up running an electric gauge.
