Oil in coolant?
Head gasket? Dont know for sure, but if there's a leak and the oil pressure is higher than the coolant, the coolant wouldn't go into the oil. You didn't have anyone without mechanichal experiance add oil to your 'stang recently did you? (Put oil in coolant overflow.):(
No but i do have a sick ammount of oil pressure. Like 60psi at idle. And i had a problem earlier with no breathers causing oil to leak out of the top of the timing cover which may of caused this.
