Oil leak at cam cover
if the leak is at the engine front cover you need a nab of sealant right where the valve cover crosses the engine front cover, where you removed that old gasket you should notice the gasket stuck to the head about 2 inches back from the front of the engine. Hard to describe sealant should be right where the head and front timing cover and valve cover all met. :shrug:
Its definetly not the pcv. I know it is the cam cover. Its just wierd that it is leaking after i put a new gasket on and torqued it down twice. I am begining to think that there is some worpage that may need to be resolved. I will check it out soon and post.
Thanks for ya'll help
