F foxyfiveohchick New Member Jan 1, 2010 3 0 0 Escondido Jan 1, 2010 #1 Jan 1, 2010 #1 I have a leak on the left side of the engine. Its smoking bad and smells like oil n gas.. possible pvc leak?
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,333 18,059 224 Massachusetts Jan 1, 2010 #2 Jan 1, 2010 #2 Prob leaking valve cover more than likely....easy fix
apollo12 New Member Dec 11, 2007 155 0 0 port st.lucie fla Jan 2, 2010 #3 Jan 2, 2010 #3 If you replace the valve cover gaskets I'd also replace the pvc valve and the screen under it.First try to tighten the valve cover bolts and see if that helps
