  • SN95 4.6L Mustang Tech
Oil on spark plug
  • Thread starter Thread starter bneal007
  • Start date Start date May 6, 2007
bneal007
17
Nashville TN
May 6, 2007
  • May 6, 2007
My engine light came on so I went to autozone and found I had a misfire on cylinder 2 and 5. I bought 2 plugs, replaced plug on cylinder 2 which looked fine, the plug on cylinder 5 had oil on it when i took out. The oil was on the tip of the plug , the part that actually goes into the head. Anyone had this problem or know what it could be?
281CI96Coupe
233
  • May 6, 2007
Oily coating caused by poor oil control. Oil is leaking past worn valve guides, piston rings, or on some race engines a possible intake gasket leak and then entering the combustion chamber.
Check for worn valve guides (NEVER knurl valve guides), intake gasket sealing alignment, as well as worn cylinder walls and piston rings. A leak down test is a good place to start for what is causing this.
http://www.centuryperformance.com/spark2.asp
EPIK
796
LEFT COAST
May 7, 2007
  • May 7, 2007
Do u have a 32v DOHC? U didnt say what kind of stang u have. On my old 97 Cobra the valve cover gaskets & sparkplug seals were leaking oil into the sparklug holes. Not sure if the sohc's have the same problem though.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 7, 2007
  • May 7, 2007
Do you own a Mustang?
bneal007
17
Nashville TN
May 8, 2007
  • May 8, 2007
Sorry, 2000 mustang gt
the98stang
2,408
Clovis, CA
May 8, 2007
  • May 8, 2007
If the oil was on the THREADS of the spark plug, you could have a major problem such as bad rings or worn valves. How many miles are on the car? What mods do you have done to it? What oil are you running?
I would stop what you are doing and compression test the car to see where the problem is. If you find one low cylinder, poor a teaspoon of oil into it, and recheck the compression. If the compression shoots up, the rings are bad. You should also perform a leak down test.
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
P
Resolved Spark plug location
  • Ptanner
  • May 17, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk May 18, 2026
Ptanner
P
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
