Oil pan gasket. HELP needed
  • Thread starter Thread starter 67GTA-FB429
  • Start date Start date May 29, 2004
67GTA-FB429
777
Tri-Cities, Wa
May 29, 2004
  • May 29, 2004
I installed my new 8qt Canton oil pan today. However in the process of putting the bolts in I managed to wrinkle the gasket and tear it.
Any advice for this incredibly painful experience would be appreciated.
I am getting new gasket and more RTV on Sunday.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
May 29, 2004
  • May 29, 2004
The best way that has always worked for me is,
put the four corner bolts in first, but only half way.
the install ALL the rest of the bolts finger tight and then
tork to spec's.
Makes putting on any pan or tin work much easier.
it helps with aligning the gaskets too.
PB
KillerKittyCat
150
Hammer Down - Behind The Wheel
May 29, 2004
  • May 29, 2004
I agree!
2nd Mustang
2,488
Southern California
May 30, 2004
  • May 30, 2004
Don't use RTV silicone. Use a gasket "dressing" that helps hold gasket in place and make for easy removal. RTV silicone allows the gasket to slip during installation, whereas gasket dressing is made for the purpose of holding gasket in place during installation.
67GTA-FB429
777
Tri-Cities, Wa
May 30, 2004
  • May 30, 2004
Like Edlebrock's gasketcinch??
This is such a PITA with the motor in the car. Hardest part was getting the end seals in place.
G
gp001
4,401
So. Cal.
May 30, 2004
  • May 30, 2004
1 piece gasket
67GTA-FB429
777
Tri-Cities, Wa
May 30, 2004
  • May 30, 2004
Let me know where I can get a one-piece for a 429.
G
gp001
4,401
So. Cal.
May 30, 2004
  • May 30, 2004
Would these work??
M-6710-A460 429/460
Designed for use with smooth rail oil pans. One-piece design, rubber bonded on steel reinforcement.
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=6129
M-6710-B460** 429/460
Designed for use with ribbed rail oil pans. One-piece design, flexible rubber.
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=6359
67GTA-FB429
777
Tri-Cities, Wa
May 30, 2004
  • May 30, 2004
ok. i will look.
67GTA-FB429
777
Tri-Cities, Wa
May 30, 2004
#10
  • May 30, 2004
  • #10
Nice call. Those would work great. Ford Racing was the one place I had not looked. THANKS!!
67GTA-FB429
777
Tri-Cities, Wa
Jun 1, 2004
#11
  • Jun 1, 2004
  • #11
Is there a preferred torque-ing sequence for the pan bolts? the books I looked at did not indicate one as such.
Ordered a one-piece gasket today
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jun 1, 2004
#12
  • Jun 1, 2004
  • #12
I used the Copper Spray Gasket stuff in a can from AutoZone or NAPA on my valve cover gaskets and NEVER had a leak or problem. Spray both sides of the gasket and bolt it down evenly. The gasket wont squirm because this stuff is real tacky. It also seems to fill the pores in the gasket to help it seal. I had to take them off once and believe me, these puppies were really suctioned to the head and cover! Check it out to see if it's recommended for oil pan gaskets too.
M
Mr44666
302
Las Vegas, NV
Jun 2, 2004
#13
  • Jun 2, 2004
  • #13
I used a one piece late model 5.0 gasket which is a perfect fit. It seemed like it would be pretty difficult to mess up. The kit comes with 4 guide pins, I could only get 2 to go in the back.
-Dave
67GTA-FB429
777
Tri-Cities, Wa
Jun 21, 2004
#14
  • Jun 21, 2004
  • #14
UPDATE: The one piece gasket finally arrived. Got everything cleaned and ready to go. Put Edlebrock gaskecinch everywhere, put the gasket in place lifted the pan up AND.......
the four corner holes in the gasket are smaller than the bolts.
This is a Ford product and it did not fit correctly. :damnit:
After throwing a few tools and cussing a lot, I took everything out, and made the corner holes bigger (removed the washer in the gasket).
Question: are the end seals supposed to be up tight against the motor, or will there be a little slop before the pan is tightened down??
67GTA-FB429
777
Tri-Cities, Wa
Jun 21, 2004
#15
  • Jun 21, 2004
  • #15
bump.
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Engine New Oil Leak Help.
  • Slo5Oh89
  • Mar 14, 2025
Fox 5.0 Mustang Tech Mar 19, 2025
Slo5Oh89
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
