  • 1994 - 1995 Specific Tech
Oil Pan Issue
  • Thread starter Thread starter jlawson94
  • Start date Start date May 19, 2010
J
jlawson94
  • May 19, 2010
I have recently purchased a 94 mustang GT that I am restoring...its in pretty rough shape as far as the body goes but i noticed that the oil pan appears to have been JB welded. Should i put an OEM back on or swap for an aftermarket seems though i already have it off. If so what should i be looking for in an aftermarket oil pan?
9
95PGTTech
302
20
  • May 19, 2010
Ever have the oil pump changed in the motor... the melling high volumes are a little taller and split my pan on the same corner...
I just dont want you to put another stock pan on and also have it crack...
If there is a HV pump in there and there is not alot done to the car id buy a stock melling pump and a new stock pan.
-Adam95gt
J
jlawson94
  • May 19, 2010
not sure on the oil pump havent tore into it yet im in iraq for another month or so but i will check it out when i return.
393strokervert
340
florida
May 19, 2010
  • May 19, 2010
mine was JB welded by the PO. haven't looked at it but I will probably swap the pan out sometime this year when I put heads on it.
to jlawson94....Thanks for your service to this country
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
May 19, 2010
  • May 19, 2010
A factory replacement oil pan is pretty affordable. Just put a factory replacement oil pump in there and a new oil pan. Unless you are getting some serious performance out of it, a big sump oil pan like a Canton just means buying more oil each oil change.
Kurt
9
95PGTTech
302
20
  • May 19, 2010
Kurt
Exacly iirc a new melling 68 was like $17-$22
hollywoodstang
1,095
May 19, 2010
  • May 19, 2010
get this pan! great for stock replacement and very affordable. I went this route for the first car and was very happy, the 2nd pan was RR Pan and it needed modification and was pain in the butt.
www.cantonracingproducts.com - 13-600 - 302 STOCK ELIMINATOR REAR SUMP PAN
Accepts everything stock including the pump, pick up, dipstick, everything, Do this one if you are taking the old one out.
J
jlawson94
  • May 20, 2010
thanks for the help fellas. I'm excited to get back and get started. but for now all i have is pictures.
ProKiller
3,064
15
78
PA
May 20, 2010
  • May 20, 2010
$234 is an affordable stock replacement pan? i'll sell you my stock pan for $20 plus shipping.
hollywoodstang
1,095
May 20, 2010
#10
  • May 20, 2010
  • #10
I thought it was $175...Man that's cheap for aftermarket oil pan, You can get that same pan for cheaper from summit or jegs.
Aftermarket cost more money but you get what you pay for and it will be better for later if you mod the car
D
Resolved Oil pan welds cracking
  • D & D Racing
  • May 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 16, 2025
revhead347
Engine Cheapy Fox body 7qt oil pans?
  • rednotch
  • Mar 25, 2025
Fox 5.0 Mustang Tech Apr 15, 2025
08GT500
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
