Oil pan leak, low oil level sensor
  • Thread starter Thread starter 1993SSP
  • Start date Start date Oct 13, 2010
1993SSP
1,194
Ky
Oct 13, 2010
  • Oct 13, 2010
Anyone had any experience fixing a leak at the low oil level sensor, mine is leaking, I took a wrench and tightened it up but the leak is still there, it didnt turn much when i took the wrench to it, is there a seal or gasket on it??
Saleen0679
876
24
49
Yakima, WA
Oct 14, 2010
  • Oct 14, 2010
Yes, there is a gasket for the sensor. It looks like a big flat rubber washer.
http://www.latemodelrestoration.com/item/LRS-6626A
E
El_CUCUY
95
RGV
Oct 14, 2010
  • Oct 14, 2010
yeah i purchased mine from resto a few years back and i havent put it on yet ... I dont drive the car much so it sits in the garage ,but im taking ou the engine this dec and will be replacing the gasket as well.
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,085
224
Massachusetts
Oct 14, 2010
  • Oct 14, 2010
There is a gasket. The original tends to dry out and crack.
I got mine from lrs....make sure you install with a little bit of rtv. Gotta do it when you do an oil change.
1993SSP
1,194
Ky
Oct 14, 2010
  • Oct 14, 2010
I fixed it, just put a oil drain plug in place of the sensor, I keep tabs on my oil pressure and oil level anyways
93project
549
52
38
El Paso, tx
Oct 15, 2010
  • Oct 15, 2010
That's what I was gonna suggest! Plug it! Chances are, it doesn't work any. and if you rely on the light coming on to warn you about oil problems, you deserve to get a seized engine
L
Luch
9
Illinois
Oct 15, 2010
  • Oct 15, 2010
Plug
I did the same thing, went to Napa and bought the cap to plug the switch. My switch was actually leaking itself not even the gasket was bad; figured the thing is useless anyhow just get rid of it...
1993SSP
1,194
Ky
Oct 15, 2010
  • Oct 15, 2010
Mine was the switch leaking as well, came down to a new switch for $49 plus shipping or the plug that was $3.00. It was a no brainer for me!
Jason 302
685
71
68
Newark, Ohio
Dec 21, 2011
  • Dec 21, 2011
After a few years of my car sitting around and leaking, and me blaming the rear main, I finally discovered today that my sensor is leaking as well. Did I understand correctly that a drain plug is the same size and thread? The wires are cut on mine anyway and it is useless.
Jason 302
685
71
68
Newark, Ohio
Dec 21, 2011
#10
  • Dec 21, 2011
  • #10
Upon further investigation, looks like it takes a 20mm x 1.5 pitch thread.
88Ttopp
20
Gun suck state of California
Jan 15, 2013
#11
  • Jan 15, 2013
  • #11
Mine too, I replaced the gasket and later found the sensor was leaking also. The price is now $78.99 for the dam sensor and $11.99 for the gasket!!!!! Next oil change it is getting plugged!!
Stephen
fredfifty
5 Year Member
Nov 23, 2011
318
57
59
SF Bay Area
May 11, 2020
#12
  • May 11, 2020
  • #12
for those that plugged it and discarded the sensor, did you bypass the low oil light? or did you just take the bulb out from behind the dash? also, how did the rtv work out? should rtv be applied on both sides of the gasket or just the oil pan side?
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
Engine Oil leaking
  • greenflash79
  • Apr 1, 2026
  • 2007 - 2014 Shelby GT500 Tech
2007 - 2014 Shelby GT500 Tech Apr 6, 2026
greenflash79
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
