ONEBADPNY New Member Nov 10, 2002 195 0 0 FREMONT, NEBRASKA Sep 5, 2004 #1 Sep 5, 2004 #1 will the oil pan on a 95 302 fit into a 66 coupe.
rbohm Founding Member Apr 12, 2002 6,698 550 204 tucson,az Sep 6, 2004 #2 Sep 6, 2004 #2 the oil pans will physically interchange on all 221-302 ford blocks. the problem you have however is that the rear sump will not clear the steering linkage. the front sump pans are still very easy to find though.
ONEBADPNY New Member Nov 10, 2002 195 0 0 FREMONT, NEBRASKA Sep 6, 2004 #3 Sep 6, 2004 #3 i have one off a 67 289 but it didn't look like the bolt hole would line up. i did not try to put it on the car so maybe i need to try again. thanks
