OIL PAN TROUBLE ! HELP?
  • Thread starter Thread starter hardflip
  • Start date Start date Nov 5, 2004
H
hardflip
17
Washington
Nov 5, 2004
  • Nov 5, 2004
I'm trying to get the oil pan off of my 89 5.0 convertible and I've been following the instructions pretty close but still can't seem to get it out. I'm not sure if I can even get the engine raised anymore. Has anyone had this problem or know something I'm forgetting?
Ourobos
260
Nov 6, 2004
  • Nov 6, 2004
I assume you're trying to pull it with the engine in the car. Where is your trouble, getting it over the oil pickup? Make sure ALL the bolts are out of it if it seems stuck.
rd
3,316
63
109
Ocean Springs MS
Nov 6, 2004
  • Nov 6, 2004
Make sure you get all the bolts, especially those that go into the timing cover in the front.
I have not done this in a Mustang, I would rather pull the engine, and did that because I put a hole in the oil pan a couple years ago.
In the car, I think you still have to get the pan low enough to remove at least the oil pump pickup, and maybe the pump to get room to pull the pan.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 6, 2004
  • Nov 6, 2004
Here are some notes to change the oil pump, the pan removal is part of the process.
Been there, done that - You can do it in the car. Disconnect the battery at the battery ground terminal remove the fan and fan shroud. Both motor mounts will need to have the large nuts that secure them to the frame removed. The trans mount will also have to be loosened, and it is a good idea to remove the drive shaft.
I also had to disconnect the cat pipes at the headers to get the engine high enough to remove the oil pan. Be prepared to have to drop the steering rack and disconnect the steering shaft. Jack up the engine with a wood block under the oil pan and watch for things that bind or hoses/electrical wiring that may need to be disconnected. I put a couple of wood blocks between the headers and the frame to support the engine. You will likely need to jack up the rear of the transmisison as well to get the required clearance.
Scrape the pan mating surfaces clean as possible - old gasket stuck to the surfaces are a source of leaks.
Get a high volume/heavy duty pump, and a replacement HD pump shaft. FMS makes one, and ARP does too. When you install the pump, the funny looking washer thingy goes on the part of the shaft that fits into the hex socket in the distributor shaft. It keeps the shaft in place when you remove the distributor, which you will have to do to prime the pump. Forget to put it on, and the pump shaft can come loose and fall down in the bottom of the oil pan.
There is a one piece oil pan gasket which will help re-assembly if you can find it. If you can't get this gasket, use weather strip adhesive to secure the cork gasket to the pan rails and the rubber strips to the bearing caps. Read the instructions on the adhesive carefully to make sure the gaskets are permanently stuck in place and won't move when you slide the pan in place . Use lots of blue silcone sealer on top of the front and rear rubber seals where they mate with the pan.
Fill with oil, replace the filter. Reconnect the battery, switch the ignition on to enable the gages, but DON'T crank the car. Remove the distributor and use a 1/4" hex socket to turn the pump counterclock wise (same direction as distributor rotation) until you see oil pressure (an external gage is a great help long about now). and keep turning for about 30 sec after you see the pressure come up. A reversible drill is the best tool to use to turn the 1/4" socket. The pressure should come up to about 50-80psi with cold oil. Once you see good pressure, check for obivous leaks, and then and only then, lower everything back into place and bolt down the mounts and anything else you had to take loose.
Re-install the distributor and set the timing with the engine running using a timing light (don't forget to disconnect the SPOUT plug and reconnect it when finished)12-14 degrees BDC is good . Start up and check for leaks, let it warm up and look again for leaks. It took me 2 days plus, but I am old and slow, maybe your granny is faster.
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
M
Hey all
  • Mikalikey
  • Aug 20, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 20, 2026
Mikalikey
M
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Engine New Oil Leak Help.
  • Slo5Oh89
  • Mar 14, 2025
Fox 5.0 Mustang Tech Mar 19, 2025
Slo5Oh89
