Oil pan
undo the motor mounts and lift the motor up and undo all the bolts around the pan and remove. reverse that for putting the new one in......drain oil first and don't forget to fill when done. And mite as well change the oil filter since you did the oil..
Or pay a garage to do it if you don't feel like doing it. Should only take around 3-4 hours
