Oil Pressure Dropping Help !!!!
smitty194
15
Car is 5sp, when i stop at light or stop sign an press clutch in oil pressure drops to zero an car cuts off , when i press throttle oil pressure is normal , when driving everything runs fine just when i got to press in clutch an stop thats here the problem is , does anybody no Wat is causing this thanks for any replies
Duh!
First thing I should have said is check the oil!
If the oil level is very low, when you slow, and the oil moves forward, the pickup could be uncovered.
When the oil flow is stopped, the lifters collapse, and the engine can't run.
