oil pressure gauge installed but now strange psi!
kingc
85
Spring/Houston, TX
I am noticing that at warm idle tge gauge reads 50 while feiving say at 2200 rpm the gauge reads 95 psi. It stays that high until I come
To a stop at a light for example. I have recently changed the oil and use mobil one full synthetic. So what could be going on here? The sender seems to be working fine but I've been that at cruising rpm I should be at 60 psi 95 seems high is this bad?
im using a 2000 sohc pump, and at anything over idle warm its at 95 psi and cruising at 60 in 5th then its at around 75 or 80, at idle when warm its at 50. Did i damage the sender do you think?
it's possible that you have a bad sender.. But you should also check your connections and wires..
Also you may want to go to the website for the company that made your gauge and see what they have on there for troubleshooting.
