Oil pressure gauge
  • Thread starter Thread starter Silver91GT50
  • Start date Start date Mar 6, 2008
Silver91GT50
  • Mar 6, 2008
I just got the car a couple weeks ago. Its a 1991 Mustang GT Premium. It has the usual issues, but one thing i didnt notice when I bought it was the oil pressure gauge. Im not sure if this is an electrical problem or what but when the vehicle is idling sometimes the oil pressure gauge drops to where it would be if the vehicle were off. Then, almost immediately it returns to its normal position. Also when the vehicle's a/c is switched on it does it as well. Any inclination as to what it might be? Just as a side note, the speedo jumps around at low speeds but once you get past twenty mph it evens out. This is what makes me think it might just be a faulty gauge/ cluster but i would rather be sure then be sorry. Thanks!
mustangfan1990
505
Lenoir, North Carolina
Mar 6, 2008
  • Mar 6, 2008
well sounds like the oil pressure gauge ground is loose or it is grounding somewhere....as far as you speedo thats not electric. It jumps because you cable needs some grease...
ninety15.0
1,336
  • Mar 7, 2008
The signal wire for the oil pressure sending unit is just a little cup that sits on top of a metal post on the sending unit. On the drivers side of the block, just above the oil filter is where the "log" and OP sending unit are located.
Make sure this signal wire cup is making good contact with the sending unit post. It could also be that the sending unit is just old. Perhaps a new one would be in order.
Yup...the speedo cable probably needs some grease. If you are going to do through the hassle of removing it...you might as well put a new one in there. They are a ****** to change....so ask yourself if the bouncy speedo bothers you that much! good luck with the new whip.
Silver91GT50
  • Mar 11, 2008
i hate to beat this to the ground, but the car seems to idle funny. It appears to have a connection to the oil pressure gauge because whent the car idles at about 750 rpms, then raises up to about 900-1000 then drops and when the idle drops back to 750, the oil pressure gauge fluctuates. This sometimes happens repeatedly and when you hit the gas or drive, the problem stops. Im thinking its the oil sending unit. So i'm going to replace it because it probably wouldnt be a bad idea.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
