  • 1994 - 1995 Specific Tech
oil pressure problems
  • Thread starter Thread starter GT_green_GT
  • Start date Start date Jun 12, 2007
GT_green_GT
118
  • Jun 12, 2007
I did a full rebuild on my engine over the winter. Im a tech student and did it as part of my class. When the engine was removed it ran fine. Didnt burn oilor anything. I rebuilt it knowing that i had future plans for it and wanted it to be in good condition and wanted something to learn on. I fully rebuilt the engine. New bearings and rings. My cylinders were perfect along with every other part in the engine. I polished the crank and when i was done it looked brand new. I used clevite bearings and plastigauged them. The whole time my instructor was watching over. The cam bearings were replaced. I did not get into the oil plugs. The engine started and ran fine. Ive put nearly 700 miles on it since. i wanted to see how it ran after all my work. After i was done my oil pressure had dropped. anywhere below 1000 rpms the factory tach drops down to nothing. i thought maybe the oil thinned out. so since it was a rebuild i went ahead and changed it. I used supertech 10w-30. I noticed that the oil pressure is fine tell it is warmed up. then anything below 1000 rpms and it drops. im in the process of getting an autometer gauge to really see where the numbers are at. any one have any ideas?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jun 12, 2007
  • Jun 12, 2007
You're wise in putting a real gauge on it. The stock one is basically useless, as I'm sure you'll notice shortly after the addition of the Autometer one. Mine's done that for years. A bad ground can do it, and can actually make it show its head a little worse since the factory ground is on the front cover, right next to the oil pressure sending unit.
GT_green_GT
118
  • Jun 13, 2007
so there is suppose to be a ground that goes to the front cover. is it that stud right off the side of it?
True 5.0
237
Southeastern Wisconsin
Jun 13, 2007
  • Jun 13, 2007
The ground strap that is important for the gauges is the one in the center of the drive side frame rail and runs down to the motor mount stud. Mine was disconnected and my gauges were all screwed up.
JamesBaumann
624
Vancouver Island
Jun 13, 2007
  • Jun 13, 2007
Mine does that exact same thing. Oil pressure will read fine and then once the car is fully warmed up and I am idling, the guage will drop all the way down to 0. im not really too concerned about it, I figure it is probably just the guage. Not to mention, when you are idling at around 600-800 rpm's, you probably wont have a lot of oil pressure anyways.
True 5.0
237
Jun 13, 2007
  • Jun 13, 2007
The factory pressure gauge is nothing more than a glorified idiot light. It DOES NOT read pressure. It is only "on" (needle at 12:00) or "off" (needle at 9:30). I do believe 15 PSI is the threshold.
GT_green_GT
118
  • Jun 14, 2007
all my other gauges are fine. especially with a fresh rebuild i shouldnt have oil issues. Im gonna get a autometer gauge as soon as possible and check out whats goin on.
WhiteDevil
2,717
San Diego
Jun 14, 2007
  • Jun 14, 2007
With my 347 i installed an autometer oil pressure gauge. At cold start and under load i get about 50psi. When it warms up and is idling i get 26-27psi when warm under load it is at 50psi.
GT_green_GT
118
  • Jun 14, 2007
im not getting any noise or anything. its just that when u rebuild that and 700 miles later its doin that ya kinda freak out. seeing other poeple have similar problems its a stress reliever. my oil pressure kicks back in a cruising speeds.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 14, 2007
#10
  • Jun 14, 2007
  • #10
i would make sure your ground is good, replace the stock oil pressure "switch" and throw the autometer on there for good insurance
did you reuse the stock pump or go with aftermarket?
GT_green_GT
118
#11
  • Jun 15, 2007
  • #11
regreting it....but the stock one
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
SBF rebuild with no oil pressure NEED HELP
  • Falcon67
  • May 27, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2025
horse sence
